Civil Engineering Association Software Software Product Non Engineering Software Folder Guard v8.4
Folder Guard v8.4
 abdulazizk
Ethiopia
User ID: 26237
Threads: 18
Likes: 371 in 30 posts
Given Likes: 178
02-10-2013, 10:41 AM (This post was last modified: 02-11-2013, 11:57 AM by Dell_Brett.)
Folder Guard for Windows 8, 7, Vista, XP
[Image: 72122914193597839366.jpg]
[Image: 65522405992236030258.png]
Folder Guardยฎ is a powerful computer security program that you can use to control access to files, folders, and other Windows resources, such as Control Panel, Start Menu, and so on. You can use Folder Guard to lock your personal files and folders with passwords, to stop other users from peeking into your records. You can even completely hide your private folders from virtually all applications, and such folders would remain invisible until you enter a valid password. You can also protect sensitive system files from modification or destruction, disable access to the removable drives, restrict access to Control Panel, and more.
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
[-] The following 12 users Like abdulazizk's post:12 users Like abdulazizk's post
  โ€ข blaze, 3fan, ska51, usman, hignacio43, arceon, ting tsai huang, techno, vinnunsam, ykhackhack, TAFATNEB, ranger
 ykhackhack
United States
User ID: 36960
Likes: 3,670 in 707 posts
Given Likes: 8693
02-11-2013, 09:54 AM
Hello friends
When I downloaded the rar file
Avast 7.0.1474 gave a warning for malicious software for WinPrc.exe as Win32:Trojan-gen
I just want to make sure
  โ€ข
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42494
Just my 2 cents:
I Never install any software as "silent install".
Only with a separated "Medicine", fully scanned before.
Just a tip.
This post and above will be removed in a few days...
The original post will be edited and both notes added.
  โ€ข
Threads: 1,118
02-11-2013, 03:48 PM
I use this software (an oder version) and this is the reason i spent some time to see where is the problem. The file is infected but if you can download it (disable the anivirus and enable it back after finishing the downloading) use the procedure bellow.
Use WinRAR and expand the downloaded file (is a self extracting archive). In the created folder "Folder gaurd" - strange english used for distribute a virus - search for the folder Autoplay and inside for folder Docs. Copy it's content in a new folder (the exe file, a reg file and a text file).
The exe file is a self extracting archive too and is infected. Use WinRAR and extract the archive. The result is the real installer and WinPrc.exe (the virus) your antivirus will delete and if not delete it.
Use the installer, enter the reg file in registry after installing and that's all.
  โ€ข Dell_Brett, 3fan, ykhackhack, melekeen
  Folder Lock Grunf 3 7,440 10-12-2009, 12:23 PM
Last Post: Learner
