Civil Engineering Association eBooks Journals, Papers and Presentations STRENGTH–DUCTILITY PERFORMANCE OF FLANGED BEAM SECTIONS CAST OF HIGH-STRENGTH CONCRET
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
12-29-2012, 12:06 AM
FLEXURAL STRENGTH–DUCTILITY PERFORMANCE OF FLANGED BEAM SECTIONS CAST OF HIGH-STRENGTH CONCRETE
Author: A. K. H. KWAN AND F. T. K. AU | Size: 257 KB | Format: PDF | Quality: Unspecified | Publisher: A. K. H. KWAN AND F. T. K. AU | Year: 2004 | pages: 15
[Image: 05877332195077700304.jpg]
Flanged sections are often used for long-span concrete beams to maximize their structural efficiency. However,
although for the same sectional area a flanged section could render a higher flexural strength, it would also lead
to a lower flexural ductility, especially when heavily reinforced. Thus, when evaluating the flexural performance
of a beam section, both the flexural strength and ductility need to be considered. In this study, the post-peak flexural
behaviour of flanged sections is evaluated by means of an analytical method that uses the actual stress–strain
curves of the materials and takes into account strain reversal of the tension reinforcement. From the numerical
results, the flexural strength–ductility performance of flanged sections is investigated by plotting the strength and
ductility that could be simultaneously achieved in the form of design graphs. It is found that (1) at the same
overall dimensions and with the same amount of reinforcement provided, a flanged section has lower flexural
ductility than a rectangular section; (2) at the same overall dimensions, a flanged section has inferior strength–
ductility performance compared to a rectangular section; and (3) at the same sectional area, a flanged section has
better strength–ductility performance compared to a rectangular section.
[-] The following 7 users Like asim99's post:7 users Like asim99's post
  • kowheng, ting tsai huang, malc, ykhackhack, blaze, Dell_Brett, KhaLed-S.E
  Prediction of Concrete Tensile Strength from its Compressive Strength: an Evaluation yakwetu 0 4,258 03-06-2017, 05:06 PM
Last Post: yakwetu
  Splitting Tensile Strength and Compressive Strength Relationships at Early Ages yakwetu 0 3,834 03-06-2017, 05:03 PM
Last Post: yakwetu
  Tensile Strength of Low, Medium, and High-Strength Concretes at Early Ages yakwetu 0 4,187 03-06-2017, 04:54 PM
Last Post: yakwetu
  Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 5,138 03-16-2016, 09:41 AM
  Strength reduction FEM in stability analysis of soil slopes subjected to transient un PinkPant 0 5,589 06-03-2015, 07:40 AM
Last Post: PinkPant
  The strength of struts yanburak 2 6,483 12-13-2014, 05:11 PM
Last Post: Veggeta
  Thermal degradation of bending strength of plywood and oriented strand board: a kinet TAFATNEB 0 3,854 06-03-2014, 10:36 PM
