Civil Engineering Association eBooks Journals, Papers and Presentations EXACT EVALUATION OF THE LOCATION OF THE OPTIMUM TORSION AXIS
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
11-28-2012, 10:34 PM
Author: E. M. MARINO AND P. P. ROSSI | Size: 125 KB | Format: PDF | Quality: Unspecified | Publisher: E. M. MARINO AND P. P. ROSSI | Year: 2003 | pages: 14
[Image: 40354165689522112343.jpg]
The paper addresses the issue of the evaluation of a reference axis which in multistorey buildings can play the
same role as the elastic centre in one-storey schemes. In this regard the authors propose an improvement to the
procedure previously suggested by Makarios and Anastassiadis for the evaluation of the position of the optimum
torsion axis. The above-mentioned researchers based their evaluation on a parametric analysis of asymmetric
frame-wall systems and thus defined the location of the optimum torsion axis only approximately. The authors,
instead, face the problem from an analytical point of view and propose mathematical expressions that rigorously
define the position of the same axis. Some examples are finally reported aiming at comparing the two approaches
and highlighting the improvements brought by the rigorous approach to the approximate determination of the
location of the optimum torsion axis.
[-] The following 10 users Like asim99's post:10 users Like asim99's post
  â€¢ kowheng, malc, blaze, LiviuM, zrilek, terrorruban, slowet, Dell_Brett, arceon, KhaLed-S.E
  Optimum design of steel frames using a multiple-deme GA with improved reproduction op arshiakh 0 3,564 04-26-2013, 07:57 PM
Last Post: arshiakh
  A unified formulation of the piecewise exact method for inelastic seismic demand... preceptor 0 3,957 10-31-2009, 07:41 AM
Last Post: preceptor
