Civil Engineering Association eBooks Journals, Papers and Presentations Acrosswind Response of Reinforced Concrete Chimneys
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
11-27-2012, 04:18 PM
Author: C-M. Cheng and Ahsan Kareem | Size: 1.13 MB | Format: PDF | Quality: Scanner | Publisher: Elsevier Science Publishers | Year: 1992 | pages: 12
[Image: 47740818716049965346.jpg]
The acrosswind response of isolated reinfe~c~d concrete chimneys of circular
cross-section is studied using wind tunnel tests, full-scale measureme,~ts and
response predictions based on semi-empirical methods. Three chimneys with available
full-scale response observations were selected for this study to compare their
measured and predicted responses. The wind tunnel experiments involved measurements
of unsteady aerodynamic loads on rigid models of circular cross-section and
aeroelastic response of scale models of full-scale chimenys. Tests were conducted
initially on smooth surface models, which were repeated with artificially roughened
surface. Attachment of discrete two dimensional surface roughness helps to simulate
artificially flow field features past a cylinder that represent the characteristics of high
Reynolds number flows. Utilizing this roughness configuration permits response
prediction of chimneys in boundary layer wind tunnels with a good agreement with
the observed full-scale response.
[-] The following 9 users Like asim99's post:9 users Like asim99's post
  • blaze, 3fan, david-smith, kowheng, ykhackhack, terrorruban, zrilek, malc, Dell_Brett
  SEISMIC RETROFIT OF REINFORCED CONCRETE BRIDGES WITH FIBER REINFORCED POLYMER COMPOSI TAFATNEB 0 4,621 04-03-2014, 12:26 PM
  Influence of Nonlinear SSI on the Seismic Response of Reinforced Concrete Multistory TAFATNEB 0 4,297 11-23-2013, 02:39 PM
  Influence of Axial Stress on Shear Response of Reinforced Concrete Elements miquan 0 3,932 05-25-2012, 02:28 AM
Last Post: miquan
  EFFECT OF COLUMN CAPACITY DESIGN ON EARTHQUAKE RESPONSE OF REINFORCED CONCRETE BUILD cve_jule 0 3,926 07-15-2011, 10:40 AM
Last Post: cve_jule
  Design of Continuously Reinforced Concrete Pavements Using Glass Fiber Reinforced Pol ir_71 0 4,224 02-03-2011, 05:04 AM
  Seismic response of composite frames—I. Response criteria input motion melkat 0 4,300 01-19-2011, 11:30 AM
Last Post: melkat
  THERMAL RESPONSE OF REINFORCED CONCRETE STRUCTURES IN NUCLEAR POWER PLANTS ir_71 0 4,596 11-24-2010, 06:30 AM
