Civil Engineering Association eBooks Structural Books Steel Fatigue Life of Steel Base Plate to Pole Connections for Traffic Structures
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
11-13-2012, 10:24 AM
Author: Stam, Andrew Richman, Nicholas Pool, Charles Rios, Craig Anderson, Thomas Frank, Karl | Size: 3.77 MB | Format: PDF | Quality: Original preprint | Publisher: University of Texas, Austin | Year: 2011 | pages: 165
[Image: 09998615895613778900.png]
This is a final report of an extensive experimental and analytical examination of the fatigue behavior of the welded end connection used on high-mast light structures and traffic signal masts. The weld details commonly used for these connections produce very poor fatigue performance. Their performance is a function of base plate stiffness, weld type and geometry, and number of anchor bolts. Older connection designs produced very poor fatigue performance far below the lowest American Association of State Highway and Transportation Officials (AASHTO) fatigue category. These connections can be improved by increasing the base or end plate thickness, improving weld details, and other geometric considerations. Due to the interaction of the overall connection geometry upon fatigue performance, the fatigue performance of the connection cannot be classified by simply the type of connection. The fatigue life can be improved to fatigue performance comparable to Category B but a similar connection with a thinner base plate can produce fatigue life of Category E. Recommended connections and their corresponding fatigue strength are given as well as recommended fabrication and welding specifications.
  â€¢ blaze, kowheng, Ultra Zone, jcbv, Dell_Brett, oanm2000, zrilek, Munykong, raymelito
  Behaviour and Design of Steel and Composite Connections in Fire carolinandra 0 3,351 01-10-2023, 12:16 AM
Last Post: carolinandra
  Steel Plate Shear Walls with Gravity Load: Theory and Design carolinandra 2 3,853 12-26-2022, 10:45 AM
  Fatigue Design of Steel and Composite Structures: Eurocode 3: Design of Steel Structu asim99 3 4,012 04-30-2019, 01:29 PM
  Architecturally Exposed Structural Steel: Specifications, Connections, Details carolinandra 0 1,980 01-25-2019, 11:06 AM
  Design and Analysis of Connections in Steel Structures: Fundamentals and Examples amindoxiti 1 2,776 12-16-2018, 07:54 AM
Last Post: malee
  design and analysis of fatigue resistant welded structures david-smith 2 2,718 07-20-2018, 04:15 AM
Last Post: axcel
  Proceedings of the Workshop on Connections in Steel Structures Flexi 4 5,193 06-14-2018, 01:14 PM
Last Post: gulilero
