Civil Engineering Association Various Free Discussion [PROBLEM] building a pool at a beach in the sea
[Problem] building a pool at a beach in the sea
 ernestrazak
Ghana
User ID: 53203
Likes: 0 in 0 posts
Given Likes: 1
11-09-2012, 07:18 AM
hi guys, i have this small project to design for a pool at the beach in sea water. i would appreciate it if anyone can point me in the right direction.
best Regards
Threads: 154
11-09-2012, 07:30 AM
As per my awareness,
This topic has been discussed earlier on this forum.
You may refer to the following links for proper understanding :
I hope this will help you.
Still the forum is open to discuss, in case of further confusion or non-clarity.
[-] The following 2 users Like shadabg's post:2 users Like shadabg's post
  • ykhackhack, LiviuM
 ykhackhack
United States
User ID: 36960
Likes: 3,670 in 707 posts
Given Likes: 8693
11-09-2012, 07:35 AM
@ernestrazk
1- What is the size of the pool
2- depths
3- Make sure you use pile
4- Analyze the pool for bouyancy for its empty condition
5- Provide at least fc'=4000 psi concrete
6- Min. of 4 inches of clear cover
If you need more info, please post
[-] The following 2 users Like ykhackhack's post:2 users Like ykhackhack's post
  • LiviuM, shadabg
Threads: 154
11-09-2012, 09:19 AM
Proper care should be taken, while design the water retaining structures.
As per dear friend "ykhackhack", Pool should be designed for empty conditions, because in this case, there will not be any counter pressure acting. so Max tension will be consider.
Moody's chart should be used for determining the constant in designing for Water Retaining Structure.
[-] The following 1 user Likes shadabg's post:1 user Likes shadabg's post
  • ykhackhack
