Civil Engineering Association eBooks Structural Books Concrete Flexural Anchorage Performance at Diagonal Crack Locations
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
11-07-2012, 02:38 PM
Author: Higgins, Christopher | Size: 22.16 MB | Format: PDF | Quality: Original preprint | Publisher: Oregon State University, Corvallis | Year: 2010 | pages: 166
[Image: 08491180624061978066.png]
Large numbers of reinforced concrete deck girder bridges that were constructed during the interstate system expansion of the 1950s have developed diagonal cracking in the stems. Though compliant with design codes when constructed, many of these bridges have flexural steel bars that were cut off short of the full length of the girders. When load-rating these structures, the current design specification check of tension reinforcement anchorage often controls the capacity of these bridges. The tensile force demand is controlled by the load-induced moment and shear, the number of stirrups, and the diagonal crack angle; however, little information is available regarding bond stresses developed with larger-diameter bars for full-size specimens in the presence of diagonal cracks. This research used large-size specimens to investigate the influence of diagonal cracks near flexural cutoff locations on the behavior and strength of vintage reinforced concrete girders. Testing indicated that a diagonal crack crossing the development length of cutoff longitudinal bars may not necessarily control specimen failure. Analysis showed that the required tensile demand at a diagonal crack location as predicted by AASHTO LRFD was reasonable. Two analytical methods and a non-linear finite element method were investigated for predicting the failure mode and capacity of the laboratory beams. A procedure was developed to rate existing bridges for flexural anchorage requirements around cutoff locations. Cracking characteristics indicative of flexural reinforcement slippage were defined for bridge inspection.
[-] The following 3 users Like mahyarov's post:3 users Like mahyarov's post
  â€¢ oanm2000, kowheng, Dell_Brett
  Anchorage in Concrete Construction hich 5 4,743 09-19-2015, 03:15 PM
Last Post: ibg0203
  PCA: Strength Design of Anchorage to Concrete oscargon 1 2,826 08-29-2014, 02:39 PM
Last Post: r3be1
  External Post-Tensioning Anchorage mahyarov 0 1,616 11-07-2012, 02:33 PM
Last Post: mahyarov
