Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Use of Flexible Facing for Soil Nail Walls
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
11-07-2012, 02:21 PM
Author: Pokharel, Sanat Kumar | Size: 3.54 MB | Format: PDF | Quality: Original preprint | Publisher: University of Kansas, Lawrence | Year: 2011 | pages: 70
[Image: 45909985579550735642.png]
Soil nail walls are a widely used technology for retaining vertical and nearly vertical cuts in soil. A significant portion of the cost of soil nail wall construction is related to the construction of a reinforced concrete face. The potential for use of a flexible facing design for soil nail walls to replace reinforced concrete facing was evaluated using three-dimensional finite difference modeling and physical testing of a 1.5 meter by 1.5 meter unit cell of a soil nail wall in clay. A steel mesh form of flexible facing was used as a substitute for concrete. The finite difference model predicted large vertical and horizontal deformations for surcharges of approximately 5 psi. In the physical testing, the flexible facing products performed well with regard to strength, but the facing experienced large vertical and horizontal deformations that were consistent with the numerical modeling. Based on these results, it is recommended that use of flexible facing as a substitute for reinforced concrete be limited to non-critical structures where large vertical and horizontal deformations are acceptable.
[-] The following 10 users Like mahyarov's post:10 users Like mahyarov's post
  â€¢ techno, blaze, Dell_Brett, Evandrojr, kowheng, cace-01, cristi, harsono, PinkPant, zrilek
  Guide to Soil Nail design and Construction jacs127 4 3,875 09-04-2012, 09:02 AM
Last Post: shadabg
  USDOT: Soil Nail Walls ir_71 2 3,191 08-28-2012, 09:48 AM
Last Post: shadabg
  TRL R373: The use of soil nails for the construction and repair of retaining walls abudabeeja 2 3,784 06-27-2011, 06:35 AM
  NYDOT: Design procedure for launched soil nail shallow slough treatment tuanpecc1 0 2,119 10-15-2010, 02:37 PM
Last Post: tuanpecc1
