Civil Engineering Association Software Software Product Non Engineering Software OriginLab OriginPro 8.6 SR3
 cace-01
User ID: 15651
Threads: 433
Likes: 10,522 in 867 posts
Given Likes: 7468
11-06-2012, 11:35 AM
[Image: 47060755962466309194.jpeg]
OriginLab produces professional data analysis and graphing software for scientists and engineers. Our products are designed to be easy-to-use, yet have the power and versatility to provide for the most demanding user. Origin is an easy-to-use software application that provides powerful data analysis and publication-quality graphing capabilities tailored to the needs of scientists and engineers. Origin offers unique peak-analysis and curve-fitting capabilities, over 60 customizable graph types, and analysis templates, all within a tightly integrated workbook environment.
Peak Fitting
The Peak Analyzer tool in OriginPro provides the additional capability of finding and fitting multiple peaks in your spectra. Baseline anchor points can be customized and fit with a suitable fitting function, and the baseline fitting can be included as part of the final peak fitting process. A detailed Fit Control dialog is provided to control all aspects of peak fitting including mixed peak functions, peak centers and widths, sharing parameters, and imposing bounds and linear constraints on parameters. Graphical as well as tabular results are generated as part of the final fit report.
Surface Fitting
OriginPro can fit a 3D surface to XYZ data points. The surface and data points can be displayed together, including droplines from the points to the surface.
Statistics
OriginPro expands on the statistical analysis capabilities of Origin by providing additional tools for Descriptive Statistics, Discrete Frequency Counting, Normality Tests, Correlation Analysis, One-way and Two-way Repeated Measures ANOVA, Principal Component Analysis, Hierarchical Cluster and Discriminant Analysis, many Nonparametric Tests such as Friedman ANOVA and Two-Sample Kolmogorov-Smirnov Test and Mann-Whitney Test, Survival Analysis tools including Weibull Fit and Cox Proportional Hazard Model, ROC Curves, and Power and Sample Size Tests.
Signal Processing
Advanced signal processing features in OriginPro include Short-Time FFT (STFT), Hilbert Transform, Coherence, 2D FFT and 2D FFT-based Filtering, 2D Correlation, and Wavelet analysis.
Image Handling
OriginPro offers more ways to handle your image data, including alpha blending, pixel logic, morphological filtering, and interpolated background subtraction.
Analytical Power
With so much analytical power, OriginPro is the software of choice for those who want a single data analysis and graphing solution.
[Image: tips.png]
Read the text file
[Image: homepage.png]
[-] The following 2 users Like cace-01's post:2 users Like cace-01's post
  β€’ ska51, henrybill
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
11-08-2012, 07:32 PM (This post was last modified: 11-08-2012, 07:43 PM by ssobhan.)
mirrors:
Direct link:
OriginLab OriginPro 9.0
pass: soft98.ir
[-] The following 1 user Likes ssobhan's post:1 user Likes ssobhan's post
  β€’ ska51
 henrybill
User ID: 30355
Threads: 67
Likes: 1,527 in 157 posts
Given Likes: 246
11-08-2012, 08:04 PM
Direct downloads from Homepage (only Install):
OriginLab OriginPro v8.6 SR3:
OriginLab OriginPro v9.0:
[-] The following 1 user Likes henrybill's post:1 user Likes henrybill's post
  β€’ ska51
 3fan
Romania
User ID: 29614
Threads: 141
Likes: 7,359 in 1,207 posts
Given Likes: 5546
11-08-2012, 10:51 PM (This post was last modified: 11-08-2012, 10:52 PM by 3fan.)
If you like it, CivilEA's team strongly suggested you buy it! Support the developers!
[-] The following 3 users Like 3fan's post:3 users Like 3fan's post
  β€’ blaze, lisine, ska51
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
11-09-2012, 10:05 AM
OriginLab.OriginPro.v8.6.SR3
[-] The following 2 users Like lisine's post:2 users Like lisine's post
  β€’ ska51, 3fan
 lisine
Vanuatu
User ID: 17927
Threads: 265
Given Likes: 4631
11-10-2012, 10:17 AM
Here are new links, new rar file, single extraction, no pass.
[-] The following 4 users Like lisine's post:4 users Like lisine's post
  β€’ ska51, isurya, ali akbar, diegoalmeida
  OriginLab OriginPro 2017 SR0 with Help TAFATNEB 0 4,468 12-05-2016, 07:19 PM
  OriginPro 8.5.1 SR2 Build 315 cace-01 4 10,004 06-27-2015, 08:02 PM
Last Post: daywalker
  OriginPro 8.5.0 SR1 Build 161 utan 4 8,274 11-05-2012, 05:14 PM
  OriginLab OriginPro 8.0 SR5 timosiβ„’ 9 15,608 11-16-2011, 09:20 PM
Last Post: 3fan
