Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Engineering Policy Guidelines For Design Of Spread Footings
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-29-2012, 07:20 AM (This post was last modified: 10-30-2012, 10:01 AM by lisine.)
Author: Loehr, J Erik | Size: 7.08 MB | Format: PDF | Quality: Original preprint | Publisher: Missouri University of Science and Technology, Rolla | Year: 2011 | pages: 44
[Image: 67278855403508160304.jpg]
These guidelines were developed as part of a comprehensive research program undertaken by the Missouri Department of Transportation (MoDOT) to reduce costs associated with design and construction of bridge foundations while maintaining appropriate levels of safety for the traveling public. The guidelines were established from a combination of existing MoDOT Engineering Policy Guide (EPG) documents, from the 4th Edition of the AASHTO LRFD Bridge Design Specifications with 2009 Interim Revisions, and from results of the research program. Some provisions of the guidelines represent substantial changes to current practice to reflect advancements made possible from results of the research program. Other provisions were left essentially unchanged, or were revised to reflect incremental changes in practice, because research was not performed to address those provisions. Some provisions reflect rational starting points based on judgment and past experience from which further improvements can be based. All of the provisions should be considered as “living documents” subject to further revision and refinement as additional knowledge and experience is gained with the respective provisions. A number of specific opportunities for improvement are provided in the commentary that accompanies the guidelines.
[-] The following 13 users Like mahyarov's post:13 users Like mahyarov's post
  • blaze, cace-01, isurya, PinkPant, kowheng, gulilero, rendel_©, ruaumoko, oanm2000, malc, harsono, davegabj, alibouafia
Threads: 154
10-30-2012, 05:39 AM
Engineering Policy Guidelines for Design of Spread Footings
Author: Loehr, J.E., J.J. Bowders, L. Ge, W.J. Likos, R. Luna, N. Maerz, B.L. Rosenblad, and R.W. Stephenson | Size: 7 MB | Format: PDF | Quality: Original preprint | Publisher: Missouri Department of Transportation | Year: 2011 | pages: 42
[Image: 91007264222756811161.jpg]
Abstract:
These guidelines were developed as part of a comprehensive research program undertaken by the Missouri Department of Transportation (MoDOT) to reduce costs associated with design and construction of bridge foundations while maintaining appropriate levels of safety for the traveling public. The research program was conducted by faculty, students, and staff from the University of Missouri and Missouri University of Science and Technology in collaboration with MoDOT personnel and private industry. The research program was completed in Fall 2010. These guidelines, along with several others, serve as the principal deliverables from the research program.
[-] The following 5 users Like shadabg's post:5 users Like shadabg's post
  • david-smith, blaze, ruaumoko, oanm2000, mahyarov
  LARGE SCALE LOAD TESTS AND DATA BASE OF SPREAD FOOTINGS ON SAND mahyarov 0 1,600 11-12-2012, 09:12 PM
Last Post: mahyarov
  FIELD AND LABORATORY PERFORMANCE EVALUATION OF SPREAD FOOTINGS mahyarov 0 1,594 11-12-2012, 09:08 PM
Last Post: mahyarov
  Engineering Policy Guidelines for Design of Earth Slopes mahyarov 0 1,612 10-30-2012, 08:07 AM
Last Post: mahyarov
  Engineering Policy Guidelines For Design Of Driven Piles mahyarov 0 1,875 10-29-2012, 07:23 AM
Last Post: mahyarov
  Engineering Policy Guidelines For Design Of Drilled Shafts mahyarov 0 1,721 10-29-2012, 07:22 AM
Last Post: mahyarov
  Modeling of Pile Footings and Drilled Shafts for Seismic Design mahyarov 0 1,667 10-28-2012, 06:04 AM
Last Post: mahyarov
  USDOT: Selection of Spread Footings on Soils to Support Highway Bridge Structures cargadory2k 0 2,225 09-04-2010, 07:59 PM
Last Post: cargadory2k
