Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Seismic Retrofitting Manual for Highway Structures: Part 1 & 2
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-27-2012, 03:58 PM
Seismic Retrofitting Manual for Highway Structures: Part 1 - Bridges
Author: Buckle, Ian University of Nevada, Reno Friedland, Ian Mander, John Martin, Geoffrey University of Southern California, Los Angeles Nutt, Richard Power, Maurice | Size: 15.45 MB | Format: PDF | Quality: Unspecified | Publisher: Multidisciplinary Center for Earthquake Engineering Research | Year: 2006 | pages: 656
[Image: 53208453349462204061.png]
The main objective of this research was to assess the seismic vulnerability of typical pre-1975 Washington State Department of Transportation (WSDOT) prestressed concrete multi-column bent bridges. Additional objectives included determining the influence of soil-structure-interaction on the bridge assessment and evaluating the effects of non-traditional retrofit schemes on the global response of the bridges. Overall this research highlighted the vulnerability of non-monolithic bridge decks and shear-dominated bridThis manual, which is comprised of two parts, represents the most current state-of-practice in assessing the vulnerability of highway structures to the effects of earthquakes, and implementing retrofit measures to improve performance. Part 1 of this manual focuses on highway bridges, and is a replacement for the Federal Highway Administration (FHWA) publication "Seismic Retrofitting Manual for Highway Bridges" which was published in 1995 as report FHWA-RD-94-052. Revisions have been made to include current advances in earthquake engineering, field experience with retrofitting highway bridges, and the performance of bridges in recent earthquakes. It is the result of several years of research with contributions from a multidisciplinary team of researchers and practitioners. In particular, a performance-based retrofit philosophy is introduced similar to that used for the performance-based design of new buildings and bridges. Performance criteria are given for two earthquake ground motions with different return periods, 100 and 1000 years. A higher level of performance is required for the event with the shorter return period (the lower level earthquake ground motion) than for the longer return period (the upper level earthquake ground motion). Criteria are recommended according to bridge importance and anticipated service life, with more rigorous performance being required for important, relatively new bridges, and a lesser level for standard bridges nearing the end of their useful life. Minimum recommendations are made for screening, evaluation and retrofitting according to an assigned Seismic Retrofit Category. Bridges in Category A need not be retrofitted whereas those in Categories B, C and D require successively more rigorous consideration and retrofitting as required. Various retrofit strategies are described and a range of related retrofit measures explained in detail, including restrainers, seat extensions, column jackets, footing overlays, and soil remediation.ge columns in pre-1975 WSDOT prestressed concrete multi-column bent bridges as well as the importance of including soil-structure-interaction, calibrating the force/displacement characterization of the columns to experimental test data and detailed modeling of the bridges such as expansion joint/girder interaction. In the end, the seismic assessment of bridges is a cost/efficiency issue. Each bridge is different, therefore, investing in improved analyses up front will enable an efficient use of the limited funds for bridge improvement, resulting in a significant savings overall.
[-] The following 8 users Like mahyarov's post:8 users Like mahyarov's post
  â€¢ blaze, cace-01, mgdario, kowheng, oanm2000, malc, Sumatra, TAFATNEB
 mahyarov
User ID: 1197
Threads: 452
Given Likes: 1492
10-27-2012, 05:48 PM
Seismic Retrofitting Manual for Highway Structures: Part 2 - Retaining Structures, Slopes, Tunnels, Culverts and Roadways
Author: Power, Maurice Fishman, Kenneth L | Size: 18.50 MB | Format: PDF | Quality: Original preprint | Publisher: Multidisciplinary Center for Earthquake Engineering Research | Year: 2004 | pages: 370
[Image: 44019418960761256967.png]
This manual, which is comprised of two parts, represents the most current state-of-practice in assessing the vulnerability of highway structures to the effects of earthquakes, and implementing retrofit measures to improve performance. Part 2 of this manual provides guidance on the assessment and retrofitting of typical highway structures other than bridges, including retaining walls, engineered slopes and embankments, tunnels, culverts, and pavement. Guidance is provided on (a) screening for potential seismic vulnerabilities; (b) conducting a detailed evaluation; and © describing strategies for retrofit design. In addition, discussion is provided for classifying each structure by type, construction, or expected performance. This is needed since different types of a given structure (e.g., different types of retaining walls) may have different failure modes and will therefore require somewhat different approaches to seismic vulnerability screening, detailed evaluation, and retrofitting.
[-] The following 11 users Like mahyarov's post:11 users Like mahyarov's post
  â€¢ blaze, cace-01, kowheng, oanm2000, mgdario, cristi, sodapas, TAFATNEB, ruaumoko, hatkam, Sumatra
11-20-2013, 09:12 PM
Seismic Retrofitting Manual for Highway Structures: Part 1 – Bridges
Size: 15.5 MB | Format: PDF | Quality: Unspecified | Publisher: Seismic Retrofitting Manual for Highway Structures: Part 1 – Bridges PUBLICATION NO. FHWA-HRT-06-032 JANUARY 2006 Research, Development, and Technology Turner-Fairbank Highway Research Cente | Year: 2006 | pages: 658
[Image: 90596810267071893925.png]
PREFACE
This report is a major revision of the Federal Highway Administration publication
Seismic
, which was published in 1995 as report FHWA-RD-
94-052. This edition expands the coverage of the
previous publication by including procedures
for evaluating and retrofitting re
taining structures, slopes, tunnels
, culverts, and pavements, in
addition to bridges.
It is published in two parts as follows:
Part 1: Bridges
Part 2: Retaining Structures, Slopes,
Tunnels, Culverts, and Pavements Whereas Part 1 maintains the basic format of the retrofitting proce ss described in the 1995 report, major changes have been made in this re vision to include current advances in earthquake engineering, field experience with retrofitting highway bridges, and the performance of bridges in recent earthquakes in California and elsewhere. It is the result of several years of research with contributions from a multidisciplinary team of researchers and practitioners. In particular, aperformance-based retrofit philosophy is introduced similar to that used for the performance-based design of new buildings and bridges. Performance criteria are given for two earthquake ground motions with different return periods, 100 and 1000 years. A higher level of performance is required for the event with the shorter return period (the lower level earthquake
ng, evaluation, and retrofitting according to an
gory A need not be retrofitted, whereas those in Category B may be assessed without a detailed evaluation, provided certain requirements aresatisfied. Bridges in Categories C and D require
more rigorous evaluation and retrofitting, as
  â€¢ malc, Jackass, gulilero, subin91, vardan, hatkam, blaze, Dell_Brett, bigone, Sumatra
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
11-21-2013, 10:17 AM
Direct link
Publication Number: FHWA-HRT-06-032
Date: January 2006
Seismic Retrofitting Manual for Highway Structures: Part 2 – Retaining Structures, Slopes, Tunnels, Culverts and Roadways
Publication Number: FHWA-HRT-05-067
Date: August 2004
[-] The following 8 users Like bigone's post:8 users Like bigone's post
  â€¢ blaze, malc, TAFATNEB, Jackass, Dell_Brett, Sumatra, marion33, kowheng
  Seismic Retrofitting: Learning from Vernacular Architecture ssobhan 0 1,612 02-17-2016, 10:29 AM
Last Post: ssobhan
  Seismic Design, Assessment and Retrofitting of Concrete Buildings: based on EN8 PinkPant 0 2,031 05-21-2015, 07:28 AM
Last Post: PinkPant
  SEISMIC VULNERABILITY OF OREGON STATE HIGHWAY BRIDGES TAFATNEB 0 1,458 05-02-2014, 04:45 PM
  Seismic Risk Assessment and Retrofitting miquan 3 3,783 12-23-2013, 12:58 PM
  Seismic Design, Assessment and Retrofitting of Concrete Buildings: based on Eurocode8 ynopum 5 6,105 03-29-2013, 07:23 AM
Last Post: pezhmankhan
  evaluation of seismic retrofit of reinfirced concrete structures , Part II - Experime david-smith 0 1,714 11-16-2012, 08:23 AM
Last Post: david-smith
  Seismic vulnerability assessment and retrofit recommendations for state highway bridg ssobhan 0 1,777 03-11-2012, 05:51 PM
Last Post: ssobhan
