Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Seismic Assessment and Retrofit of Existing Multi-Column Bent Bridges
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-27-2012, 03:55 PM
Author: McDaniel, Cole C | Size: 2.08 MB | Format: PDF | Quality: Unspecified | Publisher: Washington State University, Pullman | Year: 2006 | pages: 63
[Image: 11075133970537467120.png]
The main objective of this research was to assess the seismic vulnerability of typical pre-1975 Washington State Department of Transportation (WSDOT) prestressed concrete multi-column bent bridges. Additional objectives included determining the influence of soil-structure-interaction on the bridge assessment and evaluating the effects of non-traditional retrofit schemes on the global response of the bridges. Overall this research highlighted the vulnerability of non-monolithic bridge decks and shear-dominated bridge columns in pre-1975 WSDOT prestressed concrete multi-column bent bridges as well as the importance of including soil-structure-interaction, calibrating the force/displacement characterization of the columns to experimental test data and detailed modeling of the bridges such as expansion joint/girder interaction. In the end, the seismic assessment of bridges is a cost/efficiency issue. Each bridge is different, therefore, investing in improved analyses up front will enable an efficient use of the limited funds for bridge improvement, resulting in a significant savings overall.
[-] The following 5 users Like mahyarov's post:5 users Like mahyarov's post
  â€¢ blaze, cace-01, mgdario, kowheng, malc
  Advanced Design Examples of Seismic Retrofit of Structures sabooryan 2 4,721 07-08-2024, 05:38 AM
  Seismic Assessment, Behavior and Retrofit of Heritage Buildings and Monuments TAFATNEB 0 3,260 06-28-2024, 02:32 PM
  Seismic assessment of existing buildings (Parts A to C) poolmand 1 1,970 02-27-2023, 10:25 PM
Last Post: sandeepb
  Seismic Hazard and Risk Assessment poolmand 0 1,808 01-01-2023, 10:21 AM
  Seismic Rehabilitation Methods for Existing Buildings carolinandra 0 1,708 09-12-2020, 10:22 PM
Last Post: carolinandra
  European Manual for in-situ Assessment of Important Existing Structures ir_71 1 2,990 05-11-2019, 08:29 AM
  Seismic Design of Buildings and Bridges By Alan Williams S.E robertsas 12 11,666 12-22-2016, 02:26 PM
