Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Seismic Behavior of Reinforced Concrete Bridge Columns at Sub-Freezing Temperatures
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-27-2012, 03:09 PM
Author: Montejo, Luis A | Size: 12.00 MB | Format: PDF | Quality: Original preprint | Publisher: North Carolina State University, Raleigh | Year: 2008 | pages: 397
[Image: 65583179759839878743.png]
The final goal of this research was to develop recommendations for the future seismic design or assessment of reinforced concrete (RC) bridge bent structures in cold seismic regions. Ten large scale circular columns were constructed and tested under cyclic reversal of loads inside an environmental chamber in the North Carolina State University Constructed Facilities Laboratory (CFL). The columns were tested at freezing (-40°C, -40°F) and ambient (23°C, 74°F) temperatures. In order to characterize every aspect of the seismic response at low temperatures, the columns' design was governed by a desired behavior: shear dominated columns, flexural dominated columns and reinforced concrete filled steel tube columns. Results obtained show that RC members exposed to the combined effects of sub-freezing temperatures and cyclic loads undergo a gradual increase in strength and stiffness coupled with a reduction in displacement capacity. The experimental results were used to calibrate a fiber-based model and a series of static and inelastic analyses were performed to typical Alaska Department of Transportation and Public Facilities bent configurations. Based on the results obtained from the experimental tests, the non-linear simulations and a moment-curvature parametric analysis, a simple methodology was developed to account for the low temperature flexural overstrength and reduction in ductility capacity.
[-] The following 5 users Like mahyarov's post:5 users Like mahyarov's post
  • blaze, cace-01, mgdario, kowheng, malc
  Seismic Assessment, Behavior and Retrofit of Heritage Buildings and Monuments TAFATNEB 0 3,196 06-28-2024, 02:32 PM
  Seismic Design of Reinforced Concrete Buildings cace-01 10 10,164 05-25-2024, 10:30 AM
  Seismic Behavior and Design Guidelines for Steel Frame Structures with Added Viscoela david-smith 3 4,143 12-20-2022, 07:30 PM
Last Post: bridgeengineer
  Seismic Design Aids for Nonlinear Analysis of Reinforced Concrete Structures pezhmankhan 11 10,890 05-05-2019, 12:17 AM
  Dynamic Behavior of Concrete and Seismic Engineering abudabeeja 10 7,604 07-20-2018, 04:04 AM
Last Post: axcel
  Seismic Design of Reinforced Concrete structure (Notes) david-smith 1 3,262 07-10-2018, 05:22 AM
Last Post: jeevaniitn
  Nonlinear Seismic Analysis and Design of Reinforced Concrete Buildings lisine 7 6,185 07-06-2018, 09:24 PM
