Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Seismic Design of Pipe-Pin Connections in Concrete Bridges
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-27-2012, 02:17 PM
Author: Zaghi, Arash E University of Nevada Saiidi, M Saiid University of Nevada, Reno | Size: 56.97 MB | Format: PDF | Quality: Unspecified | Publisher: University of Nevada | Year: 2010 | pages: 583
[Image: 10140932274185801748.png]
Telescopic pipe-pin two-way hinges are used in concrete bridges to eliminate moments while transferring shear and axial loads from integral bridge bent caps to reinforced concrete columns. The hinges consist of a steel pipe that is anchored in column with a protruded segment that extends into the bent cap. In the absence of experimental and analytical studies, design of pipe-pin hinges has been based on pure shear capacity of the steel pipe. The primary objective of this research was to investigate the seismic performance of the current detail of pipe-pin hinges and propose necessary modifications, and to develop a reliable design method for pipe-pin hinges that reflects their actual behavior. Comprehensive experimental and analytical studies of pipe-pin connections and their components including a shake table study of a two-column pier mode were conducted.
[-] The following 2 users Like mahyarov's post:2 users Like mahyarov's post
  â€¢ cace-01, kowheng
  Seismic Design of Reinforced Concrete Buildings cace-01 10 10,374 05-25-2024, 10:30 AM
  Seismic Design Aids for Nonlinear Analysis of Reinforced Concrete Structures pezhmankhan 11 11,052 05-05-2019, 12:17 AM
  Seismic Design of Reinforced Concrete structure (Notes) david-smith 1 3,321 07-10-2018, 05:22 AM
Last Post: jeevaniitn
  Nonlinear Seismic Analysis and Design of Reinforced Concrete Buildings lisine 7 6,311 07-06-2018, 09:24 PM
  Performance-Based Seismic Design of Concrete Structures and Infrastructures amindoxiti 0 2,146 03-23-2018, 12:57 PM
  Seismic Design of Concrete Buildings to Eurocode 8 cace-01 4 3,990 11-16-2017, 10:28 PM
  Seismic Design of Buildings and Bridges By Alan Williams S.E robertsas 12 11,666 12-22-2016, 02:26 PM
