Civil Engineering Association eBooks Structural Books Concrete Rubblization of Portland Cement Concrete Pavements
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-27-2012, 09:02 AM
Author: Transportation Research E-Circular | Size: 5.76 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2006 | pages: 94
[Image: 02111138084616171139.png]
Rehabilitation of existing pavements is a top pavement priority facing transportation agencies. Hot-mix asphalt (HMA) overlays on asphalt pavements is an accepted option by all transportation agencies for restoring rideability, improving functional pavement performance, and increasing the structural capacity of the existing pavement system. HMA overlays can also be considered for application to an existing, deteriorated portland cement concrete (PCC) pavement providing measures are taken to eliminate reflection cracking emanating from the cracks and joints in the PCC pavement through the HMA overlay. One such measure is to rubblize the existing PCC pavement. This process was discussed in a two-part session on rubblization of portland cement concrete pavements at the 2005 Annual Meeting of the Transportation Research Board. The papers in this document were written following the session and are based on the presentations.
[-] The following 2 users Like mahyarov's post:2 users Like mahyarov's post
  â€¢ cace-01, kowheng
  Cement and Concrete Mineral Admixtures febo927 1 2,025 07-03-2018, 04:33 AM
Last Post: axcel
  Cement and Concrete Chemistry ir_71 0 1,661 06-13-2014, 07:10 PM
  Nanotechnology-Based System for Damage-Resistant Concrete Pavements mahyarov 0 1,494 10-29-2012, 06:22 AM
Last Post: mahyarov
  Effects of Subsurface Drainage on Performance of Asphalt and Concrete Pavements mahyarov 0 1,455 10-24-2012, 09:48 AM
Last Post: mahyarov
  Guidelines for Dowel Alignment in Concrete Pavements mahyarov 0 1,452 10-23-2012, 04:46 PM
Last Post: mahyarov
  Texturing of Concrete Pavements mahyarov 0 1,524 10-23-2012, 04:38 PM
Last Post: mahyarov
  CONCRETE MIX DESIGN _Ambuja Cement Technical Literature Series niki102 1 4,258 09-12-2012, 06:11 PM
Last Post: gulilero
