Civil Engineering Association eBooks Geotechnical Engineering Soil Investigation and Mechanics Recommended Practice for Stabilization of Subgrade Soils and Base Materials
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-25-2012, 02:59 PM
Author: Little, Dallas N Texas Transportation Institute Nair, Syam Texas Transportation Institute | Size: 1.02 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2009 | pages: 67 | ISBN: -
[Image: 34892348529162908289.png]
Long-term performance of pavement structures is significantly impacted by the stability of the underlying soils. In situ subgrades often do not provide the support required to achieve acceptable performance under traffic loading and environmental demands. Although stabilization is an effective alternative for improving soil properties, the engineering properties derived from stabilization vary widely due to heterogeneity in soil composition, differences in micro and macro structure among soils, heterogeneity of geologic deposits, and differences in physical and chemical interactions between the soil and candidate stabilizers. These variations necessitate the consideration of site-specific treatment options which must be validated through testing of soil-stabilizer mixtures. This report addresses soil treatment with the traditional calcium-based stabilizers: Portland cement, lime, and fly ash. The report describes and compares the basic reactions that occur between these stabilizers and soil and the mechanisms that result in stabilization. The report presents a straightforward methodology to determine which stabilizers should be considered as candidates for stabilization for a specific soil, pavement, and environment. The report then presents a protocol for each stabilizer through which the selection of the stabilizer is validated based on mixture testing and mixture design. The mixture design process defines an acceptable amount of stabilizer for the soil in question based on consistency testing, strength testing, and in some cases (resilient) modulus testing. Within each additive validation and mixture design protocol, an assessment of the potential for deleterious soil-additive reactions is made.
  â€¢ kowheng, Evandrojr, oanm2000, cace-01, ykhackhack, Dell_Brett, isurya, semirigid, jfjdm
  Expansive Soils, Problems and Practice in Foundation and Pavement Engineering, 1st ed toa011 4 5,825 09-21-2019, 02:39 AM
  IDENTIFICATION AND STABILIZATION METHODS FOR PROBLEMATIC SILT SOILS mahyarov 0 1,815 10-28-2012, 06:00 AM
Last Post: mahyarov
  Recommended Practice for Stabilization of Sulfate-Rich Subgrade Soils mahyarov 0 1,651 10-25-2012, 02:54 PM
Last Post: mahyarov
  Recommended Practice for Evaluation of Metal-Tensioned Systems in Geotechnical Applic mahyarov 0 1,745 10-24-2012, 10:44 AM
Last Post: mahyarov
