Civil Engineering Association eBooks Geotechnical Engineering Geophysical Engineering Geophysical Methods Commonly Employed for Geotechnical Site Characterization
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-25-2012, 05:59 AM
Author: Anderson, Neil L | Size: 1.35 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2008 | pages: 44
[Image: 99010727755156674951.png]
This circular offers an overview of 12 geotechnical geophysical methods that are commonly applied to transportation projects. Geotechnical geophysics is the application of geophysics to geotechnical engineering problems; such investigations normally extend to total depths of less than 300 ft. Geotechnical geophysical surveys are performed on the ground surface, within boreholes and water, and from the air. Using illustrations and brief examples, commonly employed geotechnical geophysical methods are described. Through summary tables and brief discussions, common applications of engineering geophysics are presented. Chapters are devoted to the selection of appropriate geophysical methods and geophysical contractors, respectively. Use of geophysics by transportation agencies is reviewed through a summary of NCHRP Synthesis 357: "Use of Geophysics for Transportation Projects" (Sirles, 2006). A detailed description of applications of geophysical methods to highway-related problems may be found at www.cflhd.gov/agm/index.htm.
[-] The following 10 users Like mahyarov's post:10 users Like mahyarov's post
  β€’ utan, cace-01, kowheng, blaze, Dell_Brett, oanm2000, Evandrojr, jacs127, jaejeong, HellboyRBJ
  An Introduction to Geophysical Exploration oanm2000 3 5,984 10-22-2014, 04:21 PM
Last Post: r3be1
  Dynamic and Transient Infinite Elements: Theory and Geophysical, Geotechnical and Geo cace-01 0 3,524 05-17-2014, 03:20 AM
Last Post: cace-01
  Geodetic Deformation Monitoring: From Geophysical to Engineering Roles timosiβ„’ 2 4,829 02-18-2014, 11:25 AM
Last Post: Mohammad6299
  Geophysical Testing of Rock and Its Relationships to Physical Properties mahyarov 0 3,393 10-27-2012, 01:59 PM
Last Post: mahyarov
  Geophysical Hazards: Minimizing Risk, Maximizing Awareness oanm2000 4 5,480 06-24-2012, 03:15 AM
  Geophysical data analysis Discrete inverse theory hazus 0 2,016 07-28-2011, 10:19 AM
Last Post: hazus
  Geophysical Electromagnetic Theory and Methods cargadory2k 0 2,207 10-19-2010, 03:30 PM
Last Post: cargadory2k
