Civil Engineering Association eBooks Traffic Engineering Performance-Related Tests of Recycled Aggregates for Use in Unbound Pavement Layers
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-23-2012, 08:21 PM
Author: Saeed, Athar | Size: 3.75 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2008 | pages: 61 | ISBN: 9780309099202
[Image: 35207765241768249911.png]
This report contains recommendations for performance-related procedures to test and select recycled hot-mix asphalt (HMA) and portland cement concrete (PCC) materials for use in unbound layers of highway pavements. The report provides a comprehensive description of research intended to help materials engineers evaluate and select the reclaimed asphalt (RAP) and reclaimed concrete pavement (RCP) materials that should contribute to good performing pavements. Also, the report describes procedures for the recommended tests. The contents of this report will be of immediate interest to materials engineers, researchers, and others concerned with the construction and performance of asphalt and PCC pavements.
  â€¢ Dell_Brett, kowheng, Mohammad6299, cace-01
  Concrete Pavement Design, Construction, and Performance Grunf 14 10,436 10-23-2015, 05:48 PM
Last Post: ibg0203
  Advances in Pavement Design through Full-scale Accelerated Pavement Testing cace-01 4 3,226 01-26-2015, 03:50 AM
Last Post: gulilero
  Pavements Unbound shadabg 1 2,135 07-10-2014, 04:32 PM
Last Post: i_kabir
  Porous Asphalt Pavement Performance in Cold Regions mahyarov 0 1,954 11-10-2012, 11:49 AM
Last Post: mahyarov
  New Simple Performance Tests for Asphalt Mixes mahyarov 0 1,862 10-27-2012, 09:07 AM
Last Post: mahyarov
  Estimating Stiffness of Subgrade and Unbound Materials for Pavement Design mahyarov 0 2,082 10-25-2012, 08:57 PM
Last Post: mahyarov
  Top-Down Cracking of Hot-Mix Asphalt Layers: Models for Initiation and Propagation mahyarov 0 1,566 10-25-2012, 02:39 PM
Last Post: mahyarov
