10-17-2012, 07:01 AM
Strut-and-Tie Model Design Examples for Bridges
Author: Christopher Scott Williams | Size: 8.54 MB | Format: PDF | Quality: Original preprint | Publisher: University of Texas | Year: 2011 | pages: 351
![[Image: 61748037013510028371.jpg]](https://pic.civilea.com/images/61748037013510028371.jpg)
Strut-and-tie modeling (STM) is a versatile, lower-bound (i.e. conservative) design method for reinforced concrete structural components. Uncertainty expressed by engineers related to the implementation of existing STM code specifications as well as a growing inventory of distressed in-service bent caps exhibiting diagonal cracking was the impetus for the Texas Department of Transportation (TxDOT) to fund research project 0-5253, D-Region Strength and Serviceability Design, and the current implementation project (5-5253-01). As part of these projects, simple, accurate STM specifications were developed. This thesis acts as a guidebook for application of the proposed specifications and is intended to clarify any remaining uncertainties associated with strut-and-tie modeling. A series of five detailed design examples feature the application of the STM specifications. A brief overview of each design example is provided below. The examples are prefaced with a review of the theoretical background and fundamental design process of STM (Chapter 2). ʺ Example 1: Five-Column Bent Cap of a Skewed Bridge - This design example serves as an introduction to the application of STM. Challenges are introduced by the bridge's skew and complicated loading pattern. A clear procedure for defining relatively complex nodal geometries is presented. ʺ Example 2: Cantilever Bent Cap - A strut-and-tie model is developed to represent the flow of forces around a frame corner subjected to closing loads. The design and detailing of a curved-bar node at the outside of the frame corner is described. ʺ Example 3a: Inverted-T Straddle Bent Cap (Moment Frame) - An inverted-T straddle bent cap is modeled as a component within a moment frame. Bottom-chord (ledge) loading of the inverted-T necessitates the use of local STMs to model the flow of forces through the bent cap's cross section. ʺ Example 3b: Inverted-T Straddle Bent Cap (Simply Supported) - The inverted-T bent cap of Example 3a is designed as a member that is simply supported at the columns. ʺ Example 4: Drilled-Shaft Footing - Three-dimensional STMs are developed to properly model the flow of forces through a deep drilled-shaft footing. Two unique load cases are considered to familiarize the designer with the development of such models.
