Civil Engineering Association eBooks Journals, Papers and Presentations Fundamental Considerations For The Finite Element Analysis Of Shell Structures
Threads: 154
10-11-2012, 11:23 AM (This post was last modified: 10-11-2012, 11:26 AM by lisine.)
Author: D. Chapellet and K. J. Bathe | Size: 1.75 MB | Format: PDF | Quality: Original preprint | Publisher: Computers & Structures, Elsevier Science Ltd. | Year: 1997 | pages: 18
[Image: 03139786056467500144.jpg]
Abstract :-
The objective in this paper is to present fundamental considerations regarding the finite element analysis of shell structures. First, we review some well-known results regarding the asymptotic behaviour of a shell mathematical model. When the thickness becomes small, the shell behaviour falls into one of two dramatically different categories; namely, the membrane-dominated and bending-dominated cases. The shell geometry and boundary conditions decide into which category the shell structure falls, and a seemingly small change in these conditions can result into a change of category and hence into a drama.tically different shell behaviour.
An effective finite element scheme should be applicable to both categories of shell behaviour and the rate of convergence in either case should be optimal and independent of the shell thickness. Such a finite element scheme is difficult to achieve but it is important that existing procedures be analysed and measured with due regard to these considerations. To this end, we present theoretical considerations and we propose appropriate shell analysis test cases for numerical evaluations.
[-] The following 9 users Like shadabg's post:9 users Like shadabg's post
  â€¢ malc, kowheng, jcbv, cace-01, 3fan, Dell_Brett, zrilek, ziggety, jonny78
  ConPrimer-2 Finite Element emmi 0 5,257 03-27-2015, 12:59 AM
Last Post: emmi
  Dynamic Finite-Element Analysis of Jointed Concrete Pavements TAFATNEB 0 5,230 03-31-2014, 10:46 PM
  FLEXURAL BEHAVIOR OF REINFORCED CONCRETE BEAMS USING FINITE ELEMENT ANALYSIS (ELASTIC TAFATNEB 0 5,189 03-31-2014, 10:22 PM
  III - 1 FINITE ELEMENT ANALYSIS OF CONFINED CONCRETE COLUMNS TAFATNEB 0 4,241 03-31-2014, 10:11 PM
  FINITE ELEMENT ANALYSIS OF BASE ISOLATED BUILDINGS SUBJECTED TO EARTHQUAKE LOADS TAFATNEB 1 5,955 11-20-2013, 07:25 AM
  A Framework for 3D Finite Element Analysis of Lateral Pile System Response asim99 0 4,358 04-27-2013, 09:53 PM
  A necessary modification for the finite element analysis of cracked members detection asim99 0 4,391 04-24-2013, 11:56 PM
