Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Worked examples according to EN1993-1-3
[Request] Worked examples according to EN1993-1-3
 LiviuM
Christmas Island
User ID: 430
Threads: 75
Likes: 3,228 in 559 posts
Given Likes: 1706
10-10-2012, 05:06 PM
Author: ECCS TC7 TWG 7.5 | Size: - MB | Format: PDF | Quality: Unspecified | Publisher: ECCS | Year: 2008 | pages: 235 | ISBN: 92-9147-000-86
[Image: 52505245901241468147.jpg]
Eurocode 3, Part 1.3, Supplementary rules for cold formed members and sheeting (EN 1993-1-3:2004) has been published. This standard replaces pre-standard ENV 1993-1-3:1996 and contains updates and revisions to the pre-standard ENV 1993-1-3.
ECCS has published document No. 114 Preliminary worked examples according to Eurocode 3 Part 1.3 (2000) prepared by ECCS TC 7 using the pre-standard ENV 1993-1-3. The original aim was to check the applicability and accuracy of the pre-standard and assist the practical use of the provisions.
This new publication replaces ECCS document No. 114. The examples have been updated following the provisions given in EN 1993-1-3. Some new examples have been also included. These examples show applicability of design provisions in EN 1993-1-3 in practice. They also help in interpretation of the guidance given in the code.
Chapter 2 contains examples related to one industrial building. Different aspects related to the design of structural components have been included.
-Example A: Roof sheeting
-Example B: Liner trays
-Example C: Purlins
-Example D: Portal frames
-Example E: End wall and wind bracing
Chapter 3 contains additional examples for specific structural elements or features of EN 1993-1-3, which are included to assist in practical use of the provision.
-Example F: C-section in compression and bending about axis of symmetry
-Example G. U-section in bending and compression
-Example H: C-section in compression
-Example I: Hat section upper chord of lattice girder
-Example J: Sheeting with stiffeners in flange and web
-Example K: Inelastic reserve of sheeting
-Example L: Double C-section as end column
The calculations are based on the provisions of EN 1993-1-3. Also parts EN 1993-1-5 and EN 1993-1-1 are required in the calculations. In some cases engineering judgement has been followed. If other methods in addition to Eurocode 3 have been used it has been clearly noted in the examples.
[-] The following 1 user Likes LiviuM's post:1 user Likes LiviuM's post
  â€¢ andersen3
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
10-17-2012, 01:47 PM
Here
[-] The following 7 users Like lisine's post:7 users Like lisine's post
  â€¢ blaze, valinhas, LiviuM, malc, kowheng, zrilek, ruaumoko
  [REQUEST] Precast Eurocode 2: design manual and Precast Eurocode 2: worked examples lapkritis 1 3,047 06-12-2011, 03:08 PM
Last Post: avscorreia
  [REQUEST] Workshop on "Bridge Design to Eurocodes" with worked examples giga 0 1,843 10-11-2010, 08:46 PM
Last Post: giga
  Please I need a link to download CESMM3 Worked Examples topsdino 1 2,188 08-19-2010, 11:17 AM
Last Post: topsdino
  Precast Eurocode 2: worked examples ocbuu 0 2,318 12-31-2009, 05:40 AM
Last Post: ocbuu
  Precast Eurocode 2---Design Manual and Worked Examples anneb361 0 2,298 09-30-2009, 03:49 PM
Last Post: anneb361
