Civil Engineering Association Software Software Product Non Engineering Software Rosetta Stone v3.4.7 - 26 Languages
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
10-09-2012, 04:18 AM
Rosetta Stone v3.4.7 - 26 Languages (Windows)
Size: 118 MB Installer Only
[Image: 55319837378135771845.jpg]
Rosetta Stone – the best program for learning the language at home. Flash allows you to teach the technique as you do in his childhood began to teach their native language – no rules, by immersion, multiple repetition and the formation of the association of a number of different areas of life, development patterns and automatisms in principle from the simple to complex, from a practical perception of writing and rules. This program will teach you not to think automatically perceive and reproduce the most ubiquitous conversational grammatical constructions that are essential for activation of your speaking and start chatting.
[Image: tips.png]
Setup:
Step 1:
In the upper right side of the screen click the middle button and choose “Add or Remove Languages”.
Step 2:
Mount your desired language pack ISO using Daemon Tools or burn it on a CD or a DVD. If you are mounting with Daemon Tools make sure no other images are mounted.
Click Add a Language Level
Step 3:
When the prompt window pops – Click Continue.
Step 4:
Once the program identifies the language pack – Click Install selected language.
Warning:
Do not do the following:
1.Update the software
2.Register the software
3.Activate the software
Doing any of the above will result in crashes and the inability to use the software properly.
Troubleshooting:
Error 2123
Go to : C:\Program Files\Rosetta Stone\Rosetta Stone Version 3\ & run program to use
If you can use it, delete old shortcut & create new shortcut to desktop.
If you cant use it, remove & reinstall.
Error 2125 "Database out of date"
- Find tracking.db3 in C:\programData\Rosetta Stone\tracking.db3 & rename it to tracking.db3.bak
- Restart your computer
- Run Rosetta Stone & Close it .
- After that rename tracking.db3.bak to tracking.db3 .
Error 1117 “An error occurred loading the speech engine”
1. Go to Windows Start and then Run.
2. Type %systemroot% and click OK. This will open a new window with folders.
3. Double-click on these folders: System32, drivers, then etc.
4. Double-click on hosts. Select Wordpad from the Open With window and click OK.
6.You may be missing the "127.0.0.1 localhost" line. If you don't see this line, re-add by typing: 127.0.0.1(Press Tab on your keyboard)localhost
7. Click the X in the upper right hand corner to exit the window. When prompted to save changes, click Save.
[Image: homepage.png]
Windows Installer:
Languages:
[-] The following 2 users Like Mohammad6299's post:2 users Like Mohammad6299's post
  • paulocs, Batman07
 Mohammad6299
User ID: 42302
Threads: 251
Given Likes: 4212
10-09-2012, 06:28 AM (This post was last modified: 10-09-2012, 07:12 AM by Mohammad6299.)
Rosetta Stone v3.4.7 Installeer + Crack:
Rosetta Stone v3.4.7 - Language Packs
Language packs for version 3 can be downloaded from the following Torrent Link:
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
or you can use this Magnet Link:
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 3 users Like Mohammad6299's post:3 users Like Mohammad6299's post
  • ykhackhack, Batman07, paulocs
 zeljko2
Guest
Guests
Likes: 0 in 0 posts
Given Likes:
10-09-2012, 07:33 AM
Cann we get link for only english language?
[-] The following 1 user Likes 's post:1 user Likes 's post
  • Batman07
 Mohammad6299
User ID: 42302
Threads: 251
Given Likes: 4212
10-09-2012, 08:40 AM (This post was last modified: 10-09-2012, 08:43 AM by Dell_Brett.)
You should download the software first and then you can download English language pack from the torrent link or lumfile.com links. Files in torrent link are separated so you can download the language you want separately.
  Rosetta Stone v3.4.5 and English Language Pack TE777 9 16,914 12-27-2010, 07:06 PM
Last Post: TE777
  ROSETTA STONE 3.3.5 ENGLISH AKOVALI 0 4,812 09-17-2009, 05:43 PM
Last Post: AKOVALI
