Civil Engineering Association Software Software Product Bentley Products RM Bridge (Select Series 3) v08.10.07.02
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
09-26-2012, 11:01 AM (This post was last modified: 09-26-2012, 03:26 PM by Dell_Brett.)
RMβ„’ Bridge (Select Series 3) v08.10.07.02 - TRIAL ONLY
[Image: 78200685150260767655.jpg]
New features compare with Select Series 2
It fixes reported common problems and adds new functionalities:
*New Interface between RM Bridge and Bentley Rebar available
*Earthquake AnalysisThe tendon geometry calculation was completely revised
*Macros for Response spectrum definitions added
-Chinese code JTG D62
-AASHTO LRFD 2007
-AASHTO LRFD 2012
-CQC Mode superposition revised
-CQCX Mode superposition extended to allow *for evaluating also concurrent values
*Steel design improved, examples and manual are available
*Localsiation improved
*Russian GUI translation completed
*Proof checks for concrete structures in accordance with SniP are partly available
*The old implementation of Hong Kong standard has been revised and adapted
*ULTCHK: Reinforcement defined at composite was not considered ? fixed
*ULTSUP: Tendon results were not treated correctly fixed
*CANTILEVER : Module did not work properly – fixed
* Element-CS: Editing an element of type Viscous Damper cleared the angle value -fixed
*SELECT Licensing: Node lock license activation does not create an entry for the used country.
*Uses now location definition of Windows operating system
[Image: tips.png]
trial
[Image: comments.png]
Install the environment for RMBridge before RMBridge
No limits to creativity
[-] The following 7 users Like jokerβ„’'s post:7 users Like jokerβ„’'s post
  β€’ blaze, oanm2000, Dell_Brett, peixoto, zrilek, vutuyen, bigone
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
09-28-2012, 06:09 PM
[-] The following 4 users Like jokerβ„’'s post:4 users Like jokerβ„’'s post
  β€’ zrilek, vutuyen, bhowmik, bigone
Threads: 1,118
12-23-2012, 04:28 AM
RM Bridge V8i
(Version: 08.10.12.01 Date: 12/20/2012 FileSize: 381.98 MB)
RM Bridge V8i Prerequisite Pack
(Version: 08.10.12.01 Date: 12/19/2012 12:00:00 AM FileSize: 417.48 MB)
  β€’ blaze, bigone, ting tsai huang, oanm2000, vutuyen, jokerβ„’
  Portable Bentley RAM Connection V8i (SELECT Series 3) 7.3.1 jamildear4u 4 17,022 09-25-2017, 06:25 PM
Last Post: Aviator
  Bentley WaterGEMS v8i Select series 5(08.11.05.61) emmi 2 10,764 09-28-2015, 08:38 PM
Last Post: jokerβ„’
  Bentley WaterGEMS V8i (SELECT series 2) 08.11.02.31 BennyP 6 15,630 01-24-2013, 07:24 AM
Last Post: jokerβ„’
  Bentley RAM Elements (SELECT Series 3) 12.05.00.12 + 12.05.01.18 update BennyP 5 17,857 09-08-2012, 03:24 AM
Last Post: ykhackhack
  Bentley RAM Concept V8i 4.1.2.5 (SELECT Series 6) BennyP 6 17,139 07-15-2012, 07:30 AM
  Bentley RAM Structural System (SELECT Series 4) 14.04.03.00 BennyP 6 14,716 04-29-2012, 09:11 PM
Last Post: jokerβ„’
  Bentley CivilStorm V8i SELECT Series 2 08.11.02.65 (30 days trial and renew) BennyP 4 12,947 02-29-2012, 11:33 AM
Last Post: saherboy
