Civil Engineering Association Various Free Discussion [PROBLEM] Software Installation Logs
[Problem] Software Installation Logs
 ykhackhack
United States
User ID: 36960
Likes: 3,670 in 707 posts
Given Likes: 8693
09-05-2012, 03:27 AM
Dear members
During installation, the softwares create, change alot of files/folders, modifies registry etc.
Is there any sure way of capturing this process, in other words the log file.
Thanks for your time
 Batman07
User ID: 22745
Threads: 35
Likes: 629 in 84 posts
Given Likes: 735
09-05-2012, 10:51 AM
You can use sofware that can make portable applications (vmware, spoon studio, etc.). It can show you what are the changes made on your computer after installing a specific program. The idea is to capture your computer before and after the installation.
[-] The following 1 user Likes Batman07's post:1 user Likes Batman07's post
  • ykhackhack
 ykhackhack
United States
User ID: 36960
Given Likes: 8693
09-05-2012, 02:09 PM
I was going to try to make some portable application with "Enigma", which works little different than others. You can use this soft, on a software which is already installed. And you have to point the soft to the files/folders you want to virtualise. And if you succeed it make one EXE file which, upon execution it does not write anything on the hard disk if you want. (big difference than other virtualising softs. This way it can work on a machine without upgrading or downgrading the environment.
 albani
User ID: 23104
Threads: 7
Likes: 683 in 78 posts
Given Likes: 1025
09-05-2012, 02:39 PM
There are some programs like Advanced Uninstaller Pro, which you can find through in this forum in the link below.
It has a monitoring plugin that monitor all the changes during the installations of programs and gives you a log file about all changes. You can find it in the installation folder named monitor.exe.
I have used it sometimes but it seem to heavy load the computer during the monitoring process.
If you can't run, keep walking.
[-] The following 1 user Likes albani's post:1 user Likes albani's post
  • ykhackhack
 ykhackhack
United States
User ID: 36960
Given Likes: 8693
09-05-2012, 03:11 PM
@albani
I have that. I think if there is no alternate or a better one I will try to utilize that.
Thanks
 RazvanMelek
User ID: 26357
Threads: 8
Likes: 203 in 28 posts
Given Likes: 23
09-05-2012, 06:27 PM
Actually you could use Process Monitor and Process Explorer from the Sysinternals Suite available from Microsoft Technet.The download and use of the tools is free of charge and they can give full info about all the things that a service,executable or any other thing does to the system registry or the files that are being accesed.They are also pretty easy to use.To get them google Sysinternals and select Process Utilities on the right side of the page.Cheers.
[-] The following 3 users Like RazvanMelek's post:3 users Like RazvanMelek's post
  • malc, ykhackhack, LiviuM
Threads: 49
09-06-2012, 06:47 AM (This post was last modified: 09-06-2012, 06:48 AM by andersen3.)
maybe this helps you
from there InstallWatch Pro seems to be right for you. maybe the others can help you eiher.
tell me if this is the thing you wanted.
[-] The following 1 user Likes andersen3's post:1 user Likes andersen3's post
  • ykhackhack
 LiviuM
Christmas Island
User ID: 430
Threads: 75
Likes: 3,228 in 559 posts
Given Likes: 1706
09-12-2012, 09:32 AM
Use a virtual machine software.
Create a virtual machine, install OS, install a tracking software.
Make a copy of the virtual machine.
Something like this:
Run tracking software.
Install software
Run tracking software in comparison mode.
Some software like SeismoSoft programs has protection and it doesn't work when it detects Sysinternals capturing driver.
You could try Sandboxie, install it, create an empty sand box and install in that sandbox your software.
You could see all modified files and you could read the registry changes with a registry hive viewer (can't remember the name).
It would be the best choice to try all this stuff each time in a clean virtual machine.
[-] The following 1 user Likes LiviuM's post:1 user Likes LiviuM's post
  • ykhackhack
