Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 933-10 Tests for geometrical properties of aggregates. Assessment of fines. Gra
08-20-2012, 02:20 PM
BS EN 933-10:2009 Tests for geometrical properties of aggregates. Assessment of fines. Grading of filler aggregates (air jet sieving)
Author: Committee B/502/6 | Size: 0.28 MB | Format: PDF | Quality: Unspecified | Publisher: CEN | Year: 2009 | pages: 14 | ISBN: 9780580638312
[Image: 81836834986091880550.jpg]
This European Standard describes the reference method used for type testing and in cases of dispute for determining the particle size distribution up to 2 mm size of natural or manufactured origin filler aggregate using air jet sieving. For other purposes, in particular factory production control, other methods may be used provided that an appropriate working relationship with the reference method has been established.
NOTE A wet sieving procedure conforming to EN 933-1 can be used as an alternative method. However, this procedure is not applicable for mixed filler.
  â€¢ 3fan, zrilek, devilmaycry, kowheng, Jackass, lisine, peixoto, Dell_Brett
02-24-2014, 05:16 PM
  â€¢ st77bel, Dell_Brett, utan, Mohammad6299
  BS EN 1097-2:2010 Tests for mechanical and physical properties of aggregates. Methods ir_71 1 2,432 07-21-2017, 04:39 PM
  BS EN 933-8:2012 Tests for geometrical properties of aggregates. Assessment of fines. mybest 1 2,483 06-05-2014, 02:28 PM
  BS EN 933-3:2012 Tests for geometrical properties of aggregates. Determination of par mybest 1 2,547 10-02-2013, 05:47 AM
  BS EN 1744-1:2009 Tests for chemical properties of aggregates. Chemical analysis ir_71 2 2,971 08-04-2013, 06:18 AM
Last Post: st77bel
  BS EN 1097-10:2002 Tests for mechanical and physical properties of aggregates. Determ ir_71 0 1,964 08-20-2012, 02:43 PM
  BS EN 1097-5:2008 Tests for mechanical and physical properties of aggregates. Determi ir_71 0 1,687 08-20-2012, 02:37 PM
