Civil Engineering Association Software Software Product Non Engineering Software Axsware Pdf To DWG Converter 3
 rusty
Hungary
User ID: 17227
Threads: 56
Likes: 1,880 in 283 posts
Given Likes: 539
08-01-2012, 08:31 AM
Axsware Pdf To DWG Converter 3.0
[Image: 46683548691819446736.png]
[Image: 66866593946312687563.png]
aXsware PDF to DWG Converter, a stand alone application allows you to convert PDF to DWG and DXF in few easy steps. aXsware is able to convert the vector content of PDF files. When a PDF contains raster content, you can choose to convert a raster PDF to editable vector lines in a DWG or just preserve the original image as a raster image reference in the drawing.
* Easy to use
Just within 3 steps you'll get the DWG and DXF generated. Choose PDF, select output file type and click "convert". Could not be easier.
* Fast conversion
Within seconds, you'll get the drawing which you want.
* High quality
Auccurately retains texts, solides, hattch patterns, lines, colors and automatic restore arcs in the converted drawings.
[Image: tips.png]
1)Setup (aXsware-P2D) file
...after setup
2)Select register
3)Invent an email
4)Copy serial
5)Enjoy.
[Image: homepage.png]
[Image: comments.png]
SERIAL: 0276ef177304baf4b0ceb07f34
Tested on Win 7 64bit.
[-] The following 21 users Like rusty's post:21 users Like rusty's post
  β€’ kowheng, Andrew seah, slowet, malc, Dell_Brett, AlmostThere, ykhackhack, jokerβ„’, oscargon, blaze, henrybill, albani, knrsa, Rami11, tooraj41, azas, ranger, Quantumm, Petrit, redtony, jonny78
 fbx_rdnk
United States
User ID: 37936
Threads: 2
Likes: 65 in 15 posts
Given Likes: 140
08-01-2012, 04:21 PM
Mirror Link
Includes notes and serial from original post as a text file in the zip folder.
[-] The following 11 users Like fbx_rdnk's post:11 users Like fbx_rdnk's post
  β€’ Dell_Brett, seriousboy, ykhackhack, maher2612000, 3fan, blaze, chenamoy, Rami11, visu, Petrit, jonny78
 rusty
Hungary
User ID: 17227
Threads: 56
Given Likes: 539
09-25-2013, 08:28 AM
All above links are dead.
pass
[-] The following 19 users Like rusty's post:19 users Like rusty's post
  β€’ chottabhai, ali akbar, Dell_Brett, viet2010, TAFATNEB, Petrit, sodapas, 3fan, albani, oanm2000, redtony, Jackass, uetian19, jonny78, mgdario, malc, dweenz, strengbas, karroumk
  STDU Converter 2.0.61.0 [DJVU to PDF Converter] Dell_Brett 0 4,940 12-20-2010, 07:45 AM
Last Post: Dell_Brett
