Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 61400-2:2006 Wind turbines Part 2: Design requirements for small wind turbines
 Arigato
Ireland
User ID: 740
Threads: 29
Likes: 893 in 88 posts
Given Likes: 277
03-11-2010, 11:19 PM (This post was last modified: 02-10-2014, 01:42 PM by BennyP.)
Wind Turbines
Part 1: Design Requirements
BS En 61400-1:2005
[Image: 71722433476967700849.jpg]
[-] The following 18 users Like Arigato's post:18 users Like Arigato's post
  β€’ Dell_Brett, abudabeeja, kowheng, timosiβ„’, riprap, draluka, ambrish, roaming79, hans01, foxxx2010, LiviuM, lisine, nordmann, malc, knrsa, febo927, tuanpecc1, cargadory2k
11-12-2010, 03:50 PM (This post was last modified: 05-06-2012, 02:14 AM by mybest.)
EN ISO/IEC 61400 Wind turbines
Contents:
EN ISO/IEC 61400-2:2006 Wind turbines -- Part 2: Design requirements for small wind turbines
EN ISO/IEC 61400-3:2009 Wind turbines -- Part 3: Design requirements for offshore wind turbines
IEC 61400-3:2009 specifies additional requirements for assessment of the external conditions at an offshore wind turbine site and specifies essential design requirements to ensure the engineering integrity of offshore wind turbines. Its purpose is to provide an appropriate level of protection against damage from all hazards during the planned lifetime. Focuses on the engineering integrity of the structural components of an offshore wind turbine but is also concerned with subsystems such as control and protection mechanisms, internal electrical systems and mechanical systems. It should be used together with the appropriate IEC and ISO standards, in particular with IEC 61400-1. This publication is to be read in conjunction with <a href=''http://webstore.iec.ch/webstore/webstore.nsf/artnum/037855''>IEC 61400-1:2005</a>.
EN ISO/IEC 61400-11:2003 Wind turbine generator systems -- Part 11: Acoustic noise measurement techniques
Presents measurement procedures that enable noise emissions of a wind tubine to be characterized with respect to a range of wind speeds and directions. Allows comparisons between different wind turbines. May be applied by wind turbine manufacturers, purchasers, operators and planners or regulators.
DD IEC TS 61400-13:2001, IEC TS 61400-13:2001 Measurement of mechanical loads
ISO/IEC TS 61400-14 Wind turbines – Part 14: Declaration of apparent sound power level and tonality values
This part of IEC 61400 gives guidelines for declaring the apparent sound power level and
tonality of a batch of wind turbines. The measurement procedures for apparent sound power level and tonality are defined in IEC 61400-11.
EN 61400-21:2008 Wind turbines -- Part 21: Measurement and assessment of power quality characteristics of grid connected wind turbines
IEC 61400-21:2008 covers the definition and specification of the quantities to be determined for characterizing the power quality of a grid connected wind turbine; measurement procedures for quantifying the characteristics; and procedures for assessing compliance with power quality requirements, including estimation of the power quality expected from the wind turbine type. The main changes with respect to the previous edition deal with interharmonics and current distortions (<9 kHz); response to voltage dips; active power ramp rate limitation and set-point control; reactive power capabilities and set-point control; grid protection and reconnection time after grid faults.
Draft IEC 61400-22: Wind turbine certification
EN ISO/IEC 61400-25-1:2007 Wind turbines -- Part 25-1: Communications for monitoring and control of wind power plants - Overall description of principles and models
EN ISO/IEC 61400-25-2:2007 Wind turbines -- Part 25-2: Communications for monitoring and control of wind power plants - Information models
EN ISO/IEC 61400-25-3:2007 Wind turbines -- Part 25-3: Communications for monitoring and control of wind power plants - Information exchange models
EN ISO/IEC 61400-25-4:2008 Wind turbines -- Part 25-4: Communications for monitoring and control of wind power plants - Mapping to communication profile
EN ISO/IEC 61400-25-3:2007 Wind turbines -- Part 25-5: Communications for monitoring and control of wind power plants - Conformance testing
Dear friends, if someone of you has the missing standards from this standard series, please share it.
  β€’ kowheng, toa011, shaqee, Dell_Brett, oanm2000, zrilek, hans01, foxxx2010, toni, cpwd, jcbv, LiviuM, nhim4mat2006
 datagap
User ID: 24267
Threads: 46
Likes: 695 in 68 posts
Given Likes: 176
01-28-2011, 04:46 AM (This post was last modified: 01-28-2011, 07:14 AM by Dell_Brett.)
BS EN 61400-2:2006 Wind turbines Part 2: Design requirements for small wind turbines (IEC 61400-2:2006)
Author: IEC TC 88 | Size: 1.1 MB | Format: PDF | Publisher: CENELEC | Year: 2006 | pages: 94
[Image: 45746680997293487477.png]
This part of IEC 61400 deals with safety philosophy, quality assurance, and engineering integrity and specifies requirements for the safety of Small Wind Turbines (SWTs) including design, installation, maintenance and operation under specified external conditions. Its purpose is to provide the appropriate level of protection against damage from hazards from these systems during their planned lifetime.
This part of IEC 61400 is concerned with all subsystems of SWT such as protection mechanisms, internal electrical systems, mechanical systems, support structures, foundations and the electrical interconnection with the load.
While this part of IEC 61400 is similar to IEC 61400-1, it does simplify and make significant changes in order to be applicable to small turbines.
This part of IEC 61400 applies to wind turbines with a rotor swept area smaller than 200 sq. m, generating at a voltage below 1 000 V a.c. or 1 500 V d.c.
This part of IEC 61400 should be used together with the appropriate IEC and ISO standards.
Moderator Note:
This file is present (first) in the link posted above
[-] The following 10 users Like datagap's post:10 users Like datagap's post
  β€’ zrilek, oanm2000, usman, toa011, hans01, toni, blaze, slowet, PinkPant, Grunf
05-06-2012, 05:44 AM (This post was last modified: 02-28-2015, 12:20 AM by Grunf.)
New working links, the password is the same like in post #1.
  β€’ jcbv, slowet, Jackass, Dell_Brett, 3fan, oanm2000, malc
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
02-09-2014, 04:29 PM (This post was last modified: 02-28-2015, 12:22 AM by Grunf.)
Author: IEC TC 88 | Size: 1.015 MB | Format: PDF | Quality: Unspecified | Publisher: CENELEC | Year: 2006 | pages: 94
[-] The following 2 users Like arshiakh's post:2 users Like arshiakh's post
  β€’ Dell_Brett, knrsa
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
01-28-2019, 12:40 PM
BS EN 61400-2:2006
[-] The following 14 users Like lisine's post:14 users Like lisine's post
  β€’ Photon, vvvv, oanm2000, Nita1391, zrilek, Dell_Brett, kowheng, tuanpecc1, cargadory2k, PinkPant, rami1976, er.shyams, malc, monter
  BS EN 12812:2008 Falsework - Performance requirements and general design ir_71 1 2,886 05-05-2019, 10:29 AM
  Wind Loading - A Practical Guide to Wind Loads on Buildings lamkin 6 6,119 05-25-2018, 10:21 PM
Last Post: axcel
  BS EN 1340/AC:2006 Concrete kerb units - Requirements and test methods ir_71 2 3,146 07-22-2017, 07:41 AM
  BS EN ISO 22475-1:2006 part 1 Geotechnical Investigation and Testing ir_71 1 2,313 03-25-2015, 03:42 PM
Last Post: Mohammad6299
  BS EN 1932:2001 External blinds and shutters. Resistance to wind loads. Method of tes mybest 1 2,170 02-21-2013, 08:27 AM
Last Post: arshiakh
  BS EN 10305 part 1 to part 6- Steel tubes for precision applications mybest 0 2,060 11-28-2011, 06:48 AM
Last Post: mybest
