Civil Engineering Association eBooks Structural Books Concrete fib Bulletin 40 FRP reinforcement in RC structures (final draft)
06-01-2012, 04:25 AM
Author: FIB Task Group 9.3 | Size: 6.87 MB | Format: PDF | Quality: Original preprint | Publisher: FIB | Year: 2007 | pages: 160 | ISBN: 9782883940802
[Image: 28095653896274054057.jpg]
fib Bulletin 40 deals mainly with the use of FRP bars as internal reinforcement for concrete structures. The background of the main physical and mechanical properties of FRP reinforcing bars is presented, with special emphasis on durability aspects. For each of the typical ultimate and serviceability limit states, the basic mechanical model is given, followed by different design models according to existing codes or design guidelines.
Composite FRP materials are still relatively new in construction and most engineers are unfamiliar with their properties and characteristics. The second chapter of this bulletin therefore aims to provide practising engineers with the necessary background knowledge in this field, and also presents typical products currently available in the international market.
The third chapter deals with the issue of durability and identifies the parameters that can lead to deterioration, which is necessary information when addressing design issues. A series of parameters is used to identify the allowable stress in the FRP after exposure for a specified period of time in a specific environment.
The bulletin covers the issues of Ultimate Limit States (primarily dealing with flexural design), Serviceability Limit States (dealing with deflections and cracking), Shear and Punching Shear and Bond and Tension Stiffening. It provides not only the state-of-the-art but also in many cases ideas for the next generation of design guidelines.
The final chapter deals with the fundamental issue of design philosophy. The use of these new materials as concrete reinforcement has forced researchers to re-think many of the fundamental principles used until now in RC design. The bulletin ends with a discussion of a possible new framework for developing partial safety factors to ensure specific safety levels that will be flexible enough to cope with new materials.
[-] The following 32 users Like ir_71's post:32 users Like ir_71's post
  β€’ Jackass, Grunf, david-smith, malc, kowheng, Dell_Brett, ruaumoko, peixoto, avge, miquan, agelos100, oanm2000, zrilek, SR71, gulilero, marion33, melkat, maartenneef, vvvv, Clouseau, erthqkengnrβ„’, pousin, DamirDz, simanta, stigtg, Hengki, mgdario, ibg0203, blaze, lisine, ssobhan, LiviuM
 brandizzo
User ID: 26147
Threads: 12
Likes: 366 in 68 posts
Given Likes: 140
09-27-2013, 07:02 AM
The following link seems to be alive
for every probem new link is provided
[-] The following 5 users Like brandizzo's post:5 users Like brandizzo's post
  β€’ Dell_Brett, lisine, subin91, vardan, ronnie_150
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
09-27-2013, 03:45 PM
[-] The following 5 users Like ssobhan's post:5 users Like ssobhan's post
  β€’ isurya, ruaumoko, chenamoy, LiviuM, giga
  Fiber-Reinforced Polymer: Reinforcement for Concrete Structures abudabeeja 1 2,980 05-21-2019, 06:35 AM
  Strengthening of Concrete Structures with Adhesive Bonded Reinforcement cace-01 4 3,869 03-12-2017, 09:37 PM
Last Post: Veggeta
  FIB 14: Externally bonded FRP reinforcement for RC structures kowheng 4 2,774 12-15-2015, 06:50 AM
Last Post: rusty
  FIB 40: FRP reinforcement in RC structures Mohammad6299 1 1,895 04-03-2014, 07:34 AM
Last Post: junaid
  Non-metallic (FRP) Reinforcement for Concrete Structures : Proceedings of the Second asim99 0 1,526 11-27-2012, 08:51 PM
  Design of Concrete Structures Using High-Strength Steel Reinforcement mahyarov 0 1,525 10-23-2012, 10:20 AM
Last Post: mahyarov
