Civil Engineering Association eBooks Traffic Engineering USDOT - Life Cycle Cost Analysis for Pavement Type Selection
 david-smith
United States
User ID: 43924
Threads: 209
Likes: 4,023 in 582 posts
Given Likes: 1085
05-20-2012, 02:41 PM (This post was last modified: 09-14-2014, 04:18 PM by usman.)
Author: South Carolina Department of Transportation/FHWA | Size: 0.7 MB | Format: PDF | Quality: Original preprint | Publisher: South Carolina Department of Transportation/FHWA | Year: 2008 | pages: 141
[Image: 26131399326827557921.jpg]
This report summarizes the findings from a research investigation conducted to evaluate LCCA practices
among state highway agencies for pavement type selection process, and proposes a probabilistic LCCA
approach for use in South Carolina. This investigation was based on analysis of data obtained from a
preliminary and a final survey of states across the U.S. and provinces across Canada. The surveys were
designed to gauge the level of LCCA activity in different states as well as to solicit information on specific
approaches that each state is taking for pavement type selection. The responses obtained from the surveys
were analyzed to observe the trends and ranges of various input parameters that feed into the LCCA process.
Based on the data from surveys, selected states whose LCCA practices exemplified a progressive and a
comprehensive approach were identified and further questioned on specific aspects of their respective LCCA
approaches. Based on this analysis, a probabilistic-based LCCA approach is proposed for use with pavementtype
selection process in South Carolina. Also, specific recommendations on range of values for different
input parameters based on the survey data are made. Where no adequate database exists for certain LCCA
input parameters, suggestions are offered for developing a database of values for future use .
In addition to developing a protocol for a probabilistic LCCA approach, different LCCA software
such as REALCOST, DARWin and other customized software used by specific states were explored.
Amongst these, REALCOST software developed by Federal Highway Administration (FHWA) was found to
be widely used by several state agencies and most comprehensive in its treatment of different input
parameters. Further, FHWA has been instrumental in providing support to customize the REALCOST
software to meet individual state’s needs. Based on these findings, REALCOST software was proposed as
preferred software for use with conducting LCCA for pavement-type selection.
[-] The following 6 users Like david-smith's post:6 users Like david-smith's post
  β€’ kowheng, oanm2000, malc, Jackass, Dell_Brett, Administrator
  [REQUEST] Pavement Design: Materials, Analysis, and Highways cace-01 1 3,713 10-21-2020, 05:55 PM
Last Post: oonan
  Analysis of Pavement Structures ibg0203 0 1,818 01-31-2016, 06:33 PM
Last Post: ibg0203
  ACPA - EB220 Life Cycle Cost Analysis A Guide for Comparing Alternate Pavement Design mybest 1 2,475 03-13-2015, 04:51 AM
Last Post: p_vosoughi
  Advances in Pavement Design through Full-scale Accelerated Pavement Testing cace-01 4 3,309 01-26-2015, 03:50 AM
Last Post: gulilero
  Paving Materials and Pavement Analysis (GSP 203) hich 2 4,505 10-22-2014, 03:32 PM
Last Post: hessi
  Contributions of Pavement Structural Layers to Rutting of Hot-Mix Asphalt Pavement mahyarov 0 1,820 10-24-2012, 10:59 AM
Last Post: mahyarov
  NCHRP - R703 Guide for Pavement-Type Selection mahyarov 0 1,638 10-23-2012, 09:15 AM
Last Post: mahyarov
