Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Which Design Concept for Prestressed Steel? (AISC)
[Request] Which Design Concept for Prestressed Steel? (AISC)
Away  serra
Portugal
User ID: 16643
Threads: 13
Likes: 284 in 54 posts
Given Likes: 94
05-15-2012, 02:59 PM
Author: Tochacek, Miloslav; Amrhein, Francis Gene | Size: ??? MB | Format: PDF | Quality: Unspecified | Publisher: AISC
Prestressed steel structures are those in which, during manufacture, assembly, or exploitation, deliberate stresses are produced of precise magnitude, direction, and period of duration. The most significant aims of prestressing are: enlargement of the elastic range in which the structure works; redistribution of internal stresses or forces; improvement of stability; increase of fatigue resistance; decrease in deformations; wider use of high strength steels. Some examples of the many types of prestressed steel structures and methods of prestressing are: rigid basic structures (girders, trusses, frames, masts, towers, etc.) prestressed by high strength tendons; systems or networks of prestressed flexible strings (hanging roofs and walls, etc.); multi-layer and hybrid beams or vessels (simultaneous use of different materials as concrete and steel, carbon steel and quenched-tempered steel, etc.); statically indeterminate structures prestressed by enforced displacement of redundant restraints (usually by enforced shifting of some redundant supports or by compelled assembly of some elements fabricated with planned dimension "inaccuracies"); removal or exploitation of residual, secondary, or other "parasite" stresses (from welding, temperature treatments, mechanical operations with steel in cold state, unwanted constructional rigidity of some details, etc.). Prestressed structures utilizing tendons are the most widely used and most economical.
  â€¢
 Diquan
Costa Rica
User ID: 41
Threads: 23
Likes: 1,205 in 128 posts
Given Likes: 781
05-15-2012, 07:51 PM
Dear serra,
In this link is your file:
[-] The following 2 users Like Diquan's post:2 users Like Diquan's post
  â€¢ blaze, serra
 usmanliang
User ID: 24118
Likes: 85 in 47 posts
Given Likes: 0
05-16-2012, 12:52 AM
Dear Serra, I have seen this book, but it is not from US ( AISC ), but from Russian and the use of the prestress steel just to reduce the vertical deflection for long span structureHappy
  â€¢
Away  serra
Portugal
User ID: 16643
Threads: 13
Given Likes: 94
05-17-2012, 02:04 PM
Hi there,
It may very well be, but I've found it in AISC Library...
  â€¢
  [REQUEST] AISC - Steel Construction Manual 14th Edition mastermind 11 11,962 03-14-2014, 08:42 PM
Last Post: pelon2040
  [REQUEST] AISC steel tips fred2010 1 2,020 01-11-2014, 01:13 PM
Last Post: fred2010
  [REQUEST] AISC Design Guide 26: Design of Blast Resistant Structures mastermind 1 2,317 07-04-2013, 01:13 PM
Last Post: ssobhan
  [REQUEST] AISC National Steel Conference - paper rcl1 0 1,508 02-11-2013, 07:06 AM
Last Post: rcl1
  [REQUEST] AISC ALLOWABLE STRESS DESIGN manzoor_quadri 1 1,848 10-06-2012, 03:07 PM
Last Post: manzoor_quadri
  [REQUEST] Parametric Study of Tendon Profiles in Prestressed Steel Plate Girder serra 1 1,964 08-11-2012, 02:09 AM
Last Post: gulilero
  [REQUEST] Earthquake-resistant design based on energy concept renaldi 2 2,330 08-26-2011, 12:28 AM
Last Post: Badis
