Civil Engineering Association eBooks Journals, Papers and Presentations ACI Span/Thickness Limits for Deflection Control
 miquan
Vietnam
User ID: 631
Threads: 204
Likes: 3,748 in 387 posts
Given Likes: 1331
05-15-2012, 12:17 PM
Author: Noel J. Gardner | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: ACI | Year: 2011 | pages: 8
[Image: 20961093573328128398.png]
Predicting the deflection serviceability of reinforced concrete members is fraught with uncertainties, which include imperfect knowledge of the limiting serviceability criteria, the material properties, and the load history including construction loads and the service load. The serviceability criteria can be immediate deflection/curvature or incremental deflection/curvature. Most codes offer two methods for control of deflections. The designer may choose to calculate the deflections and check that these computed deflections are less than specified allowable limits. Alternatively, the codes give specified maximum span-depth ratios for which serviceability can be assumed to be satisfied and deflections do not need to be calculated. This paper compares the deemed-tocomply span/thickness limits of ACI 318-08, CSA A23.3-04, BS 8110-97, AS 3600-2009, Eurocode 2 (2004), ACI Committee 435 revisions, and the proposals of numerous other authors.
[-] The following 15 users Like miquan's post:15 users Like miquan's post
  • ruaumoko, knrsa, kowheng, seriousboy, vvvv, zrilek, Hengki, rezart, StaadEng, malc, zinousoft, simanta, Dell_Brett, Jackass, techno
  Span-Depth Ratios for One-Way Members Based on ACI 318 Deflection Limits miquan 0 3,921 05-20-2012, 04:47 PM
Last Post: miquan
  An estimation of displacement limits for ductile systems melkat 0 4,236 11-05-2010, 04:45 PM
Last Post: melkat
