Civil Engineering Association eBooks Codes, Manual & Handbook CISC: Moment Connections for Seismic Applications
 struceng
Russian Federation
User ID: 258
Threads: 259
Likes: 10,197 in 602 posts
Given Likes: 741
09-12-2009, 12:38 PM (This post was last modified: 12-29-2011, 06:58 PM by usman.)
CISC - Moment Connections for Seismic Applications
[Image: jvtp4b1cshzgc75bvyi5.jpg]
Info:
Edition: 2008
Publisher: Canadian Institute of Steel Construction
ISBN: 0888111061
Length: 46 pages
Pdf: 1.1 Mb
Clause 27 of CSA Standard S16-01 stipulates performance criteria for beam-to-column connections for Ductile (Type D) Moment-Resisting Frames and for Moderately Ductile (Type MD) Moment-Resisting Frames and requires that they be met by means of physical testing. Connections for Limited-Ductility (Type LD) Moment-Resisting Frames may either be qualified by testing or be proportioned and detailed in accordance with the specific requirements provided in Clause 27.4.
This CISC publication concentrates on the design criteria for some of the beam-to-column connections provided in FEMA 350 'Recommended Seismic Design Criteria for New Steel Moment-Frame Buildings' (FEMA 2000a). It is intended to be used in conjunction with the National Building Code of Canada (NBCC 1995 and 2005), and CSA Standard S16-01, Limit States Design of Steel Structures.
Download Link:
Generated by Civilea PostGen v1.3
[-] The following 18 users Like struceng's post:18 users Like struceng's post
  â€¢ Dell_Brett, Dell_Brett, rendel_©, rendel_©, nuttapolk, nuttapolk, rfireman, rfireman, civilteam, u4406014, simanta, civilphongvan, Draculina, lavov, livanhg, dinu69in, julioreptil, gulilero
  CISC: Crane-Supporting Steel Structures, Design Guide oanm2000 8 8,692 04-04-2017, 10:34 AM
Last Post: hmwere
  CISC: Handbook of Steel Construction 9th Edition kowheng 3 4,519 02-24-2016, 03:21 AM
Last Post: tomtumx
  CISC: Code of Standard Practice for Structural Steel 7th Edition usman 2 3,996 05-29-2013, 06:15 AM
  CISC: Handbook of Steel Construction 8th Edition muralihare 1 2,331 02-26-2011, 02:48 AM
Last Post: usman
  CISC: Handbook of Steel Construction 7th Edition usman 1 5,100 07-14-2010, 03:38 PM
Last Post: usman
