Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Earthquake Resistant Design of Structures - Agarwal & Shirkhande
 adshrt
User ID: 8297
Threads: 35
Likes: 1,203 in 114 posts
Given Likes: 364
04-04-2012, 04:33 PM (This post was last modified: 10-28-2014, 08:47 PM by usman.)
Earthquake Resistant Design Of Structures
Author: PANKAJ AGARWAL AND MANISH SHIRKHANDE | Size: 19 MB | Format: PDF | Quality: Unspecified
[Image: 38164015148049753030.jpg]
This comprehensive and well-organized book presents the concepts and principles of earthquake resistant design of structures in an easy-to-read style. The use of these principles helps in the implementation of seismic design practice. The book adopts a step-by-step approach, starting from the fundamentals of structural dynamics to application of seismic codes in analysis and design of structures. The text also focusses on seismic evaluation and retrofitting of reinforced concrete and masonry buildings. The text has been enriched with a large number of diagrams and solved problems to reinforce the understanding of the concepts.
Intended mainly as a text for undergraduate and postgraduate students of civil engineering, this text would also be of considerable benefit to practising engineers, architects, field engineers and teachers in the field of earthquake resistant design of structures.
Table of Contents
Preface. Contributors.
Part I: Earthquake Ground Motions? Engineering Seismology. Seismic Zoning Map of India. Strong Motion Studies in India. Strong Motion Characteristics. Evaluation of Seismic
Design Parameters.
Part II: Structural Dynamics? Initiation into Structural Dynamics. Dynamics of Single Degree of Freedom Systems. Theory of Seismic Pickups. Numerical Evaluation of Dynamic Response. Response Spectra. Dynamics of Multi-Degree-of-Freedom Systems.
Part III: Concepts of Earthquake Resistant Design of Reinforced Concrete Building? Earthquake and Vibration Effect on Structures: Basic Elements of Earthquake Resistant Design. Identification of Seismic Damages in RC Buildings during Bhuj Earthquake. Effect of Structural Irregularities on the Performance of RC Buildings during Earthquakes. Seismoresistant Building Architecture.
Part IV: Seismic Analysis and Modelling of Reinforced Concrete Building? Code Based Procedure for Determination of Design Lateral Loads. Consideration of Infill Wall in Seismic Analysis of RC
Buildings. Step-by-Step Procedure for Seismic Analysis of a Four-storeyed RC Building as per IS 1893 (Part 1): 2002. Mathematical Modelling of Multi-storeyed RC Buildings.
Part V: Earthquake Resistant Design (ERD) of Reinforced Concrete Buildings? Ductility Considerations in Earthquake Resistant Design of RC Buildings. Earthquake Resistant Design of a Four-storey RC Building Based on IS 13920: 1993. Earthquake Resistant Design of Shear Wall as per IS 13920: 1993. Capacity Based Design? An Approach for Earthquake Resistant Design of Soft Storey RC Buildings.
Part VI: Earthquake Resistant Design (ERD) of Masonry Buildings?Identification of Damages and Non-Damages in Masonry Buildings from Past Indian Earthquakes. Elastic Properties of Structural Masonry. Lateral Load Analysis of Masonry Buildings. Seismic Analysis and Design of Two-storeyed-Masonry Buildings.
Part VII: Seismic Evaluation and Retrofitting of Reinforced Concrete and Masonry Buildings. Seismic Evaluation of Reinforced Concrete Buildings: A Practical Approach. Seismic Retrofitting Strategies of Reinforced Concrete Buildings. Seismic Retrofitting of Reinforced Concrete Buildings?Case Studies. Seismic Provisions for Improving the Performance of Non-engineered Masonry Construction with Experimental Verifications. Retrofitting of Masonry Buildings.
Index.
[-] The following 36 users Like adshrt's post:36 users Like adshrt's post
  β€’ marion33, tecktik, giga, ruaumoko, sodapas, maad59, ikoleci, ssobhan, Jackass, gulilero, kowheng, triance, malc, learner20, cace-01, Ultra Zone, slowet, oanm2000, simanta, Dell_Brett, abouferass88, cristi, civilgr, kevin8107, pramsm24, we_mbm, i_kabir, mgdario, shadabg, Grunf, pan5, levanduy, RyanRS, bigone, TAFATNEB, igor1234
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
12-31-2013, 04:17 PM (This post was last modified: 12-31-2013, 04:17 PM by ssobhan.)
Mirror;
[-] The following 9 users Like ssobhan's post:9 users Like ssobhan's post
  β€’ learner20, hatkam, oanm2000, jcbv, carolinandra, RyanRS, chenamoy, bigone, Dell_Brett
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
01-01-2014, 07:04 AM
mirror of post #2
Earthquake Resistant Design of Structures by Manish Shrikhande_2006- 8120328922.pdf
[-] The following 12 users Like bigone's post:12 users Like bigone's post
  β€’ learner20, ykhackhack, jcbv, vardan, blaze, Dell_Brett, simanta, ibg0203, melekeen, igor1234, ruaumoko, krishna22045
 amindoxiti
User ID: 86739
Threads: 192
Likes: 8,341 in 584 posts
Given Likes: 2619
02-17-2018, 06:21 PM (This post was last modified: 02-17-2018, 06:22 PM by amindoxiti.)
(No page is missed, OCR)
Do not worry about your difficulties in Mathematics, I can assure you mine are still greater. Β -Albert EinsteinΒ  Β  Β  Β  Β  Β
[-] The following 24 users Like amindoxiti's post:24 users Like amindoxiti's post
  β€’ red_pool61, temp1366, PinkPant, oanm2000, rami1976, ASEC, gulilero, subin91, pedzaquino, cargadory2k, rendel_Β©, zrilek, jcbv, Andrew seah, rezart, sabooryan, hatkam, promo8, caifan, simanta, Dell_Brett, ruaumoko, ajmf77, spat
  Earthquake-Resistant Design with Rubber RyanRS 7 15,007 05-13-2025, 01:35 PM
  Computer Analysis and Design of Earthquake Resistant Structures: A Handbook ziggywas1 1 3,668 05-06-2023, 12:36 PM
  Seismic Isolation Strategies for Earthquake-Resistant Construction carolinandra 1 2,865 01-30-2022, 07:45 AM
Last Post: zrilek
  Structural Dynamics In Earthquake And Blast Resistant Design poolmand 0 2,700 01-04-2022, 05:42 AM
  Earthquake Spectra and Design (Engineering monographs on earthquake criteria, structu preceptor 7 4,107 08-04-2021, 01:58 PM
Last Post: cace-01
  USACoE: Earthquake Design and Evaluation of Concrete Hydraulic Structures ir_71 1 2,922 05-11-2019, 04:35 AM
  Earthquake-resistant Structures ir_71 2 4,373 05-09-2019, 04:15 AM
