Civil Engineering Association Software Software Product Autodesk Products Autodesk Robot Structural Analyses PRO 2009
 cod-X
User ID: 45
Threads: 31
Likes: 504 in 63 posts
Given Likes: 269
01-16-2009, 04:18 PM (This post was last modified: 01-18-2009, 10:01 PM by cod-X.)
[Image: attachment.php?aid=19]
Autodesk® Robot™ Structural Analysis Professional software provides a scalable, country-specific analysis solution for the structural engineer to analyze many types of structures, including buildings, bridges, civil, and specialty structures.
Autodesk Robot Structural Analysis Professional calculates a wide variety of structures with a comprehensive collection of design codes, delivering results in minutes, not hours. This structural engineering software is versatile enough for simple structural frame analysis or complex finite element analysis and offers seamless interoperability with Autodesk companion products as well as an open application programming interface (API).
Key Features
Structural analysis features include advanced auto-meshing and modeling capabilities, fast dynamic solvers, and integrated reinforced concrete design and structural steel design modules.
Structural Analysis Software Comparison
The Autodesk structural design analysis solution is also available as Autodesk® Robot™ Structural Analysis software. Compare the two versions.
LINK:
pass for attached keygen:
.rar   keygen.rar (Size: 81.2 KB / Downloads: 128)
.jpg   Untitled.jpg (Size: 13.9 KB / Downloads: 2,006)
>> First learn from cracked software than be licensed1 <<
[-] The following 12 users Like cod-X's post:12 users Like cod-X's post
  • oanm2000, oanm2000, JCMAS, JCMAS, Panjack39, Panjack39, slim, slim, dfense, dfense, zrilek, zrilek
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Likes: 21,198 in 2,356 posts
Given Likes: 4260
01-23-2009, 06:54 AM
(01-23-2009, 12:02 AM)JIM1975 Wrote: The links are not working
I found this links:
RAPIDSHARE
EASYSHARE
Both links are interchangable;)
[-] The following 2 users Like Administrator 's post:2 users Like Administrator 's post
  • deltalead, deltalead
 Ultra Zone
Senior Member
El Salvador
User ID: 195
Threads: 98
Likes: 2,410 in 167 posts
Given Likes: 2238
01-23-2009, 03:21 PM (This post was last modified: 01-23-2009, 03:26 PM by Administrator.)
If the links doesn't work, you can download the trial version from here, and use the keygen.
Only complete the form, good look. :)
Follow the Rules
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Given Likes: 4260
02-21-2009, 08:17 AM
(02-21-2009, 07:13 AM)amaranu Wrote: hi,
I am not able to download keygen, if I click on attachments only attachments.php file is downloading and not zip OR Rar file. Kindly tell us how to download the keygen file.
test here:
Password:
[-] The following 11 users Like Administrator 's post:11 users Like Administrator 's post
  • CARLOS, CARLOS, oanm2000, oanm2000, ojancano, ojancano, amaranu, amaranu, yacinesoft, yacinesoft, Mhasan
Threads: 150
Given Likes: 28542
03-18-2009, 11:08 PM (This post was last modified: 03-18-2009, 11:30 PM by oanm2000.)
Read the instruction first
1. Unpack.
2. Install. Choose stand-alone license and use whatever you want for serial (like 123-45678901 or 888-88888888, etc.).
Restart your computer after install the software
3. After install and restart, when you run app select activate it.
4. Run the keygen and apply patch (it is patching some ECDSA stuff in memory, no files are changed, so it is IMPORTANT that you apply this patch at this moment!).
5. Make activation code for your request code using the keygen.
and
Voilá
it's done
I didn't indicate that instructions I wrote was taken directly from embrace.nfo inside keygen file...
Sorry Embrace team for the omission and Thanks a lot for your work, wherever you are...
I followed instruction step by step and everything is working. I ran two examples from McKenzie's "Examples Structural Analysis" and results were Ok
  Autodesk Robot 2026 rami1976 0 3,482 05-27-2025, 09:10 PM
  Autodesk Robot Structural Analysis Professional 2024 (x64) Multilanguage TAFATNEB 1 12,734 04-16-2023, 09:52 AM
  Autodesk Robot Structural analysis Professional 2021 rami1976 4 10,495 04-18-2020, 11:52 PM
Last Post: rigid_joint
  Autodesk Robot 2020 structural analysis professional rami1976 2 7,671 04-26-2019, 03:43 AM
  Autodesk Robot Structural Analysis Professional 2019 joker™ 2 8,176 09-07-2018, 07:49 PM
  Autodesk Robot Structural Analysis Professional 2018 rami1976 4 12,014 10-11-2017, 07:47 PM
  Autodesk ImageModeler 2009 SP1 x86 build 19113 kamran 2 7,575 04-13-2017, 01:24 AM
Last Post: jose19356
