Civil Engineering Association eBooks Journals, Papers and Presentations Simulated earthquake motions compatible with prescribed response spectra
Threads: 57
01-20-2011, 04:58 PM (This post was last modified: 10-21-2011, 06:19 AM by kowheng.)
Vanmarcke, Erik H.; Gasparini, Dario A.
PDF|RAR 6.57|6.27 MB
[-] The following 11 users Like kowheng's post:11 users Like kowheng's post
  â€¢ miquan, Dell_Brett, usman, Grunf, kg85arun, oanm2000, zrilek, fer962933, Gkatzogias, ting tsai huang, highcivil
 david-smith
United States
User ID: 43924
Threads: 209
Likes: 4,023 in 582 posts
Given Likes: 1085
05-25-2012, 04:17 AM (This post was last modified: 03-16-2013, 03:54 PM by Grunf.)
SIMQKE1 +user manual
Title: Simulation of Earthquake Ground Motions
Developer: E.H. Vanmarcke, C.A. Cornell, D.A. Gasparini, and S.N. Hou,
Department of Civil Engineering, Massachusetts Institute of Technology,
Cambridge, Massachusetts 1976.
Modified: T.F. Blake, Newbury Park, California [PC DOS version] 1990.
Category: Strong Motion Data Processing
Platform: PC DOS, MS Fortran v.4.1;
IBM, VM/CMS, Fort4H;
VAX, VM/CMS, f77
Reference: Gasparini, D.A., and E.H. Vanmarcke, "Simulated Earthquake
Motions Compatible With Prescribed Response Spectra," Department of Civil
Engineering, Research Report R76-4, Masschusetts Institute of Technology,
Cambridge, Massachusetts, January 1976.
Vanmarcke, E.H., "Structural Response to Earthquakes," Chapter 8 in
"Seismic Risk and Engineering Decisions," Edited by C. Lomitz and E.
Rosenblueth, published by Elsevier Publishing Co., Amsterdam, 1976.
Summary: SIMQKE-1 generates statistically independent accelerograms,
performs a baseline correlation on the generated motions to ensure zero
final ground velocity, and calculates response spectra. One of the options
in the program generates ground motions whose response spectra "match",
or are compatible with, a set of specified smooth response spectra. The
basis for the spectrum compatible motion generation is the relationship
between the response spectrum values for arbitrary damping and the
"expected" Fourier amplitudes of the ground motion (Vanmarcke, 1976).
The earthquakes are synthesized by superimposing sinusoidal components
with pseudo-random phase angles, and by multiplying the resulting
stationary trace by a user specified function representing the variation
of ground motion intensity with time. The program SIMQKE-1 also has the
capability to adjust, by iteration, the ordinates of the spectral density
function to improve the agreement between computed and specified response
spectra. Even without the last step, the average response spectrum (of a
set of simulated motions) will match the smooth target spectrum very
closely.
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 3 users Like david-smith's post:3 users Like david-smith's post
  â€¢ ibg0203, malc, zrilek
 highcivil
User ID: 89
Threads: 7
Likes: 270 in 33 posts
Given Likes: 630
02-23-2014, 07:38 PM
[-] The following 5 users Like highcivil's post:5 users Like highcivil's post
  â€¢ jcbv, Dell_Brett, malc, sodapas, zrilek
  Earthquake Spectra August 2010 Volume 26 Issue 3 igor1234 1 7,271 10-07-2014, 10:23 AM
Last Post: rossinando
  Earthquake Spectra by EERI melkat 98 173,227 10-05-2014, 04:42 AM
Last Post: RyanRS
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 6,132 09-05-2014, 01:46 PM
  Collapse modes of structures under strong motions of earthquake TAFATNEB 0 3,880 04-26-2014, 10:45 AM
  Response of Pure-Friction Sliding Structures to Three Components of Earthquake Excita TAFATNEB 0 4,339 04-23-2014, 03:49 PM
  EARTHQUAKE RESISTANCE OF STRUCTURES AND DYNAMIC RESPONSE USING LARGE FACILITIES EXPER TAFATNEB 0 4,288 04-23-2014, 03:44 PM
  Fatigue analysis of roof cladding under simulated wind loading asim99 0 3,822 03-31-2013, 04:31 PM
