Civil Engineering Association eBooks Codes, Manual & Handbook API RP 652: 2005 Linings of Aboveground Petroleum Storage Tank Bottoms
 jamildear4u
User ID: 5529
Threads: 85
Likes: 1,063 in 108 posts
Given Likes: 145
01-12-2012, 07:47 PM
API RP 652 - Linings of Aboveground Petroleum Storage Tank Bottoms, 2005 Third Edition
Author: American Petroleum Institute | Size: 590 KB | Format: PDF | Quality: 01-Aug-2005 | pages: 15
[Image: 41178673306965212974.jpg]
This recommended practice provides guidance on achieving effective corrosion control in aboveground storage tanks by application of tank bottom linings. It contains information pertinent to the selection of lining materials, surface preparation, lining application, cure, and inspection of tank bottom linings for existing and new storage tanks. In many cases, tank bottom linings have proven to be an effective method of preventing internal corrosion of steel tank bottoms.
The intent of this recommended practice is to provide information and guidance specific to aboveground steel storage tanks in hydrocarbon service. Certain practices recommended herein may also be applicable to tanks in other services. This recommended practice is intended to serve only as a guide. Detailed tank bottom lining specifications are not included.
[-] The following 6 users Like jamildear4u's post:6 users Like jamildear4u's post
  â€¢ seriousboy, malc, Jackass, kowheng, knrsa, Dell_Brett
  Handbook of Storage Tank Systems: Codes: Regulations, and Designs babak 4 5,393 08-31-2014, 10:01 AM
Last Post: bigone
  API RP 2350: 2005 Overfill Protection for Storage Tanks in Petroleum Facilities jamildear4u 1 2,790 09-23-2013, 06:21 AM
Last Post: irshad313
  API S 2015: 2001 Safe Entry and Cleaning of Petroleum Storage Tanks jamildear4u 0 1,870 01-12-2012, 08:50 PM
Last Post: jamildear4u
  API RP 651: Cathodic Protection of Aboveground Petroleum Storage Tanks ir_71 0 2,588 01-13-2011, 07:19 AM
