Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 209.2: Guide for Modeling and Calculating Shrinkage and Creep in Harde...
 portal61
Indonesia
User ID: 12856
Threads: 66
Likes: 855 in 90 posts
Given Likes: 223
01-07-2012, 09:15 AM (This post was last modified: 05-09-2023, 10:52 AM by Administrator.)
ACI 209.2R-08: Guide for Modeling and Calculating Shrinkage and Creep in Hardened Concrete
Author: ACI Committee 209 | Size: 1.06 MB | Format: PDF | Publisher: ACI | Year: 2008 | pages: 48
[Image: 63458771973115951317.jpg]
This guide is intended for the prediction of shrinkage and creep in compression in hardened concrete. It may be assumed that predictions apply to concrete under tension and shear. It outlines the problems and limitations in developing prediction equations for shrinkage and compressive creep of hardened concrete. It also presents and compares the prediction capabilities of four different numerical methods. The models presented are valid for hardened concrete moist cured for at least 1 day and loaded after curing or later. The models are intended for concretes with mean compressive cylindrical strengths at 28 days within a range of at least 20 to 70 MPa (3000 to 10,000 psi). This document is addressed to designers who wish to predict shrinkage and creep in concrete without testing. For structures that are sensitive to shrinkage and creep, the accuracy of an individual model’s predictions can be improved and their applicable range expanded if the model is calibrated with test data of the actual concrete to be used in the project.
[-] The following 13 users Like portal61's post:13 users Like portal61's post
  β€’ blaze, malc, Dell_Brett, techno, nhim4mat2006, Panjack39, lisine, yeka, Svetoslav, vvvv, ykhackhack, bigone, klsamy77
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
10-19-2012, 12:05 PM
[-] The following 9 users Like lisine's post:9 users Like lisine's post
  β€’ techno, vvvv, kowheng, Dell_Brett, ykhackhack, k2kyaw, seriousboy, bigone, jackpotjoe
Likes: 8,311 in 1,373 posts
Given Likes: 94
05-09-2023, 10:51 AM
  β€’ jcbv, babakfeyzi, PinkPant, Dell_Brett, TAFATNEB
  ACI 223: Guide for the Use of Shrinkage-Compensating Concrete ir_71 2 3,855 05-09-2023, 10:45 AM
  ACI 544.11: Measuring Shrinkage, Creep, and Transport Properties of Fiber-Rein poolmand 0 1,392 08-16-2022, 04:24 AM
  ACI 223: Shrinkage-Compensating Concrete - Guide poolmand 0 1,372 12-07-2021, 10:39 AM
  ACI 374.3: Guide to Nonlinear Modeling Parameters for Earthquake-Resistant sabooryan 1 2,321 09-14-2021, 07:44 AM
