Civil Engineering Association Software Software Product Bentley Products STAAD Foundation V8i Select S4 05.03.00.32
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
01-04-2012, 12:42 PM (This post was last modified: 01-04-2012, 12:44 PM by jokerβ„’.)
[Image: 10384912422017892691.png]
STAAD Foundation is a comprehensive foundation design program that offers the ability to model complex or simple footings, including those specific to Plant facilities such as octagonal footings supporting vertical vessels, strap beam foundations supporting horizontal vessels, ring foundations supporting tank structures, and drilled or driven pier foundations.
Common foundations such as isolated footings, combined footings, strip footings, pile caps, and mat foundations can also be designed for larger structures or using parametric wizards. It provides a streamlined workflow through its integration with STAAD.Pro and can also be used as a stand-alone program.
Efficient design and documentation is realized through its plant-specific design tools, multiple design codes with U.S. and metric bar sizes, design optimization, and automatic drawing generation. The plant-specific tools include vertical vessel foundations (octagonal and square shape supported on soil or on piles), and heat exchanger foundations (combined, two isolated and two isolated with a grade beam), tank ringwall foundations, and driven or drilled pier foundations.
Powerful modeling includes a physical modeling system, a toolkit mode, automatic pile arrangement, and FEM, which allows complex or simple layouts. The foundation toolkit mode was introduced to address the needs of special footing types like drilled pier and dead man anchor guy foundations.
Productivity is increased through the ability to utilize the structural model with the foundation model through the integration with STAAD.Pro. Changes made in the STAAD.Pro model are tracked and can be merged automatically with the foundation model. View the integrated video.
[Image: tips.png]
How to crack:
1- Open" Lic-Windows7.reg" and press Yes.
2- Open "sf4.reg" and press Yes.
3- Copy (and replace) "Bentley.liclib.dll" to C:\Program Files\Common Files\Bentley Shared\IEG\IEGLCS\
4- Copy and overwrite "IEGLicLib.dll" to (from folder 1):
C:\Windows\System32
5- Copy and overwrite "HWLockDLL.dll" to C:\Windows\System32
6- Copy and overwrite "Bentley.liclib.dll" to (from folder 3):
C:\Windows\System32
7- Copy and overwrite "SProStaadFdn.exe" to C:\Staad.foundation 5.3\SProStaad
8- Done
[Image: homepage.png]
No limits to creativity
[-] The following 36 users Like jokerβ„’'s post:36 users Like jokerβ„’'s post
  β€’ dizz, seriousboy, yeka, vvvv, 3fan, malc, kaungthant, sashka.od, learner20, cace-01, Ayman10, Milkshake, kowheng, piyush86, oanm2000, er.shyams, Dell_Brett, hapsea, Rainbow, blaze, ISTRAKTURA, rezart, zrilek, nektari0s, foxxx2010, hoxuantu, ranger, mahyarov, uncblue, Quantumm, mohcivil, narendra, versiondemo, MOSS2000, NAUTILUS87, pubudumalinda
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
02-01-2012, 04:48 PM
Mirror
[-] The following 12 users Like jokerβ„’'s post:12 users Like jokerβ„’'s post
  β€’ dshiva, Dell_Brett, maad59, barbong, oanm2000, Rainbow, rezart, zrilek, nektari0s, foxxx2010, Quantumm, NAUTILUS87
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
02-02-2012, 10:29 PM
Mirror Install Files Post#1 & Post2
[-] The following 10 users Like jokerβ„’'s post:10 users Like jokerβ„’'s post
  β€’ oanm2000, MOSS2000, Rainbow, Mouh@ndiss, rezart, zrilek, nektari0s, foxxx2010, Dell_Brett, NAUTILUS87
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
02-04-2012, 12:56 PM
[-] The following 9 users Like jokerβ„’'s post:9 users Like jokerβ„’'s post
  β€’ Mouh@ndiss, Dell_Brett, oanm2000, duazo2009, rezart, zrilek, foxxx2010, NAUTILUS87, piyush86
 andyspak2
User ID: 32354
Likes: 11 in 5 posts
Given Likes: 40
02-18-2012, 09:37 AM (This post was last modified: 02-18-2012, 11:19 AM by Dell_Brett.)
uncompress code is not working for your rar file.
Probably because the "TM" upper character is not reconized!
Moderator Note:
Use Copy/Paste (Control C --> Control V)
  β€’
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
06-24-2012, 09:19 AM
New Links
  β€’ oanm2000, Milkshake, zrilek, narendra, MOSS2000, NAUTILUS87, malc, ranger, doguparthi, lednar_ved
  STAAD Foundation Advanced x86 V09.06.01.074 RajaK 0 6,905 10-04-2021, 05:59 AM
Last Post: RajaK
  STAAD Foundation Advanced CONNECT Edition 08.04.00.21 kirankumarklk 1 5,872 06-27-2018, 08:46 AM
Last Post: er.shyams
  STAAD Foundation Advanced CONNECT Edition 08.03.00.20 BennyP 0 5,179 02-11-2018, 05:31 PM
  Bentley Staad Foundation Advanced CONNECT Edition RajaK 1 7,972 01-16-2016, 10:51 AM
Last Post: Dell_Brett
  STAAD Foundation Advanced V8i (06.00.00.51) - New Release - TRIAL kardels 2 11,633 01-04-2012, 04:00 PM
  STAAD.foundation V8i SELECTseries 2 (Release 5.1) BennyP 1 8,343 04-21-2010, 05:42 AM
Last Post: kardels
  STAAD.foundation V8i Release 5.0 kardels 6 36,252 11-21-2009, 11:37 AM
Last Post: fiaz
