Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 13170:2008 Thermal insulation products for buildings - Factory made products of
12-26-2011, 09:06 AM
BS EN 13170:2008 Thermal insulation products for buildings - Factory made products of expanded cork (ICB) - Specification
Author: CEN/TC 88 | Size: 0.32 MB | Format: PDF | Publisher: CEN | Year: 2008 | pages: 36
[Image: 13348262656901560725.jpg]
This European Standard specifies the requirements for factory made products of expanded cork, which are used for the thermal insulation of buildings. The products are made with granulated cork agglomerated without additional binders and are delivered as boards without facings.
This European Standard specifies product characteristics and includes procedures for testing, evaluation of conformity, marking, labelling and packaging. Products covered by this European Standard are also used in prefabricated thermal insulation systems and composite panels; the performance of systems incorporating these products is not covered. This European Standard does not specify the required level of a given property to be achieved by a product to demonstrate fitness for purpose in a particular application. The levels required for a given application are to be found in regulations or non-conflicting standards.
Products with a declared thermal resistance lower than 0,25 m2⋅K/W, at 10 °C, or a declared thermal conductivity greater than 0,060 W/(m⋅K), at 10 °C, are not covered by this European Standard
  â€¢ Dell_Brett, kowheng, vpmohammed, Jackass, peixoto
  BS EN 14629:2007 Products and systems for the protection and repair of concrete structures ir_71 2 3,592 02-11-2022, 09:56 AM
Last Post: CAMSECT
  BS EN 12190:1999 Products and systems for the protection and repair of concrete struc ir_71 2 3,221 11-27-2019, 06:48 AM
  BS 7543:2003 Guide to durability of buildings and building elements, products and ir_71 2 3,207 03-13-2018, 11:22 AM
  BS EN 1170-5:Precast concrete products. Test method for glass-fibre reinforced cement yakwetu 2 2,608 04-27-2016, 02:02 PM
Last Post: abualamal
  BS EN 752:2008 Drain and sewer systems outside buildings ir_71 4 5,400 08-19-2015, 04:59 AM
Last Post: concreteok
  BS EN 12794:2005-Precast concrete products. Foundation piles PinkPant 0 1,932 06-05-2015, 11:29 AM
Last Post: PinkPant
  BS EN 1168:2005 Precast concrete products — Hollow core slabs ir_71 6 5,719 03-09-2015, 03:46 PM
Last Post: Veggeta
