Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN ISO 10722:2007 Geosynthetics. Index test procedure for the evaluation of mechan
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
12-26-2011, 12:47 AM
BS EN ISO 10722:2007 Geosynthetics. Index test procedure for the evaluation of mechanical damage under repeated loading. Damage caused by granular material
Size: 1.2 MB | Format: PDF | Publisher: BSI | Year: 31 July 2009 | pages: 12 | ISBN: 978 0 580 53190 3
[Image: 23070482695317270299.png]
BS EN ISO 10722 describes an index test procedure for simulating mechanical damage to geosynthetics, caused by granular material, under repeated loading. The damage is assessed visually and by the loss of tensile strength.
Other reference tests may be used to assess the damage caused by this test. The test method described is an index test procedure, using a standard granular material.
Contents of BS EN ISO 10722:
Foreword
Scope
Normative references
Definitions
Principle
Test specimens
Sampling
Number and dimensions of test specimens
Conditioning
Apparatus
Procedure
Damage procedure
Measurement of damage
Calculations
Test report
Bibliography
[-] The following 7 users Like mybest's post:7 users Like mybest's post
  â€¢ kowheng, Jackass, vpmohammed, ir_71, kvtasp, peixoto, Dell_Brett
 kvtasp
User ID: 7690
Threads: 60
Likes: 2,028 in 379 posts
Given Likes: 791
12-29-2011, 03:00 AM
[-] The following 1 user Likes kvtasp's post:1 user Likes kvtasp's post
  â€¢ blaze
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
02-22-2013, 07:49 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
  â€¢
  BS 8486:2007 Examination and test of new lifts before putting into service – Specific ir_71 3 3,924 12-24-2014, 08:14 PM
Last Post: Veggeta
  BS EN 14648:2007 Building hardware. Fittings for shutters. Requirements and test meth mybest 2 2,897 02-26-2013, 09:46 AM
Last Post: arshiakh
  BS EN ISO 10321:2008 Geosynthetics. Tensile test for joints/seams by wide-width strip mybest 2 2,539 02-22-2013, 08:08 AM
Last Post: arshiakh
  BS EN 383:2007 Timber structures. Test methods. Determination of embedment strength a mybest 0 2,201 11-28-2011, 06:08 PM
Last Post: mybest
