Civil Engineering Association eBooks Project Management Construction Delays, 2nd Ed: Understanding Them Clearly, Analyzing Them Correctl
 portal61
Indonesia
User ID: 12856
Threads: 66
Likes: 855 in 90 posts
Given Likes: 223
12-24-2011, 09:10 AM
Construction Delays, 2nd Edition: Understanding Them Clearly, Analyzing Them Correctly
Author: Theodore J. Trauner | Size: 14.6 MB | Format: PDF | Publisher: utterworth-Heinemann | Year: 2009 | pages: 266 | ISBN: 1856176770
[Image: 72737829140899862767.jpg]
This book provides the background information necessary to understand delays. This understanding is not geared solely to the context of disputes but rather provides a framework to help prevent disputes from occurring and to resolve questions of time as they arise during the Project.
Delays in construction projects are frequently expensive, since there is usually a construction loan involved which charges interest, management staff dedicated to the project whose costs are time dependent, and ongoing inflation in wage and material prices. Many techniques are used to analyze delays. Some of these methods have inherent weaknesses and should be avoided. This book points out the shortcomings of these faulty methods and explains how a delay analysis should be performed. It then describes specifically how the analysis is done with CPM schedules. A explanation of delays and delay damages, presented in a straightforward, accessible manner, should be useful to public and private owners, construction managers, general contractors, subcontractors, designers, suppliers, and attorneys whose work involves them in the construction industry. The discussion will include subtleties of the process, such as shifts in the critical path, and non-critical delays. The subject of damages is covered in detail, including the major categories of extended field overhead and unabsorbed home office overhead. Likewise, the damages suffered by the owner, either actual or liquidated, are also explained. Finally, a chapter is devoted to managing the risk of delays and time extensions from the viewpoints of the various parties to a construction project. A discussion of early completion schedules and constructive acceleration is also included.
Contents:
Chapter 1, “Project Scheduling,” provides an overview and definitions of basic scheduling concepts and terms that will be referred to throughout the book. It is not intended as a CPM scheduling primer. Rather, it addresses important basic concepts required for using Project schedules. Key elements include float, reviewing and approving schedules, the critical path, and early completion schedules.
Chapter 2, “Types of Construction Delays,” explains the basic categories of excusable and nonexcusable delays and the subcategories of compensable and noncompensable delays. It addresses the concept of concurrency and also non-critical delays. This primer in delays prepares the reader for the specific issues covered in succeeding chapters.
Chapter 3, “Measuring Delays—the Basics,” explains how to approach the analysis, including the starting points of as-planned schedules and as-built diagrams and how one must compare the two in order to quantify the delays that have occurred. The question of liability is addressed separately, since this determination is made most expeditiously after the specific delays have been identified.
Chapter 4, 5 and 6 travel through the actual process of analyzing delays with bar charts, CPMs, and no schedule.
Chapter 7 comments on some of the more common approaches used and the strengths and weaknesses associated with the numerous approaches used in analyzing delays
Chapters 8 through 13, “Damages to the Owner and Contractor”. Since inefficiency and acceleration costs are often time-related issues associated with delay, they have been addressed separately in the hopes that some of the myth and magic that surrounds them may be cleared away. Similarly, the topic of costs associated with noncritical delays has been given special attention, since many projects experience these with little or no recognition of the problem.
Chapter 14, “Determining Responsibility for Delay,” explains the process used to assess the party who caused the delay. The responsibility for delays is addressed separately from the delay analysis because we believe that this is the proper approach to use: first determine the activities that are delayed and the magnitude of the delay and then address responsibility or liability.
Chapter 15, “Risk Management,” could also be called “Prevention of Time-Related Problems,” since it focuses on the delay-related risks of the various parties in a construction Project. By maintaining this focus, each of the parties has a tendency to better control time and resolve delay problems as they occur.
In this new ediion, all chapters are updated to reflect the changes in the construction field since the first edition published over l6 years ago. The 2nd edition includs over 40% more information such as new methods for analyzing delays with examples of the proper approach. The author also includes a new chapter on risk managment which focuses on the delay-related risks of the various parties in a construction project.
[-] The following 14 users Like portal61's post:14 users Like portal61's post
  • maad59, kowheng, Dell_Brett, eliseo.as, cigutierrezg, Jackass, isurya, lancelee123, vpmohammed, papillon, Umer.Aleem, rkce, binh.ce, JJ-HH
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
12-10-2012, 09:20 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 2 users Like mahyarov's post:2 users Like mahyarov's post
  • Dell_Brett, richcrow1
Threads: 154
12-10-2012, 09:42 AM
The Link in post no. 3 is a separate author book, which should be merged with forum post :
The actual mirror for this original post is :
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
PDF : 32.5 mb
  Understanding Organisational Culture in the Construction Industry>>By Vaughan Coffey cordoba123 1 2,239 03-06-2013, 10:13 AM
Last Post: arshiakh
  Construction Delays : Extensions of time and prolongation claims shadabg 0 1,647 12-10-2012, 09:38 AM
Last Post: shadabg
  Understanding the Construction Client abudabeeja 1 2,470 03-29-2011, 10:23 AM
