Civil Engineering Association eBooks Water & Hydraulic Engineering Moment Analysis for Subsurface Hydrologic Applications
 ska51
User ID: 11535
Threads: 382
Likes: 9,406 in 1,251 posts
Given Likes: 4017
12-19-2011, 05:30 PM
Moment Analysis for Subsurface Hydrologic Applications (Water Science and Technology Library)
Author: Rao S. Govindaraju, Bhabani S. Das | Size: 4.70 MB | Format: PDF | Publisher: Water Science and Technology Library | Year: 2007 | pages: 292 | ISBN: 1402057512
[Image: 32920324802767269535.jpg]
Product Description:
This book deals with the concept of moments, and how they find application in subsurface hydrologic problems-particularly those dealing with solute transport. This book will be very valuable to researchers who are beginning to learn about moment analysis, and will also be of interest to advanced researchers as well. Both temporal and spatial moments are dealt with in some detail for a wide variety of problems. Several examples using experimental data, both from laboratory columns and field experiments, are provided to give the readers a clear idea about the scope of this method. Apart from conventional uses of moments for solute transport problems, this book contains chapters dealing with use of moments in interval computing, vapour phase transport applications, transfer functions to subsurface tile drains, and construction of breakthrough curves from knowledge of moments.
Mirror:
"Downstream is Weaker"
[-] The following 4 users Like ska51's post:4 users Like ska51's post
  â€¢ Jackass, kowheng, kg85arun, Dell_Brett
  Distributed Hydrologic Modeling Using GIS TAFATNEB 3 2,541 08-01-2017, 07:47 AM
Last Post: ska51
  Hydrologic Time Series Analysis: Theory and Practice ska51 1 2,003 04-17-2014, 06:59 AM
Last Post: Mohammad6299
  Advances in Data-Based Approaches for Hydrologic Modeling and Forecasting ska51 1 1,952 04-10-2014, 05:01 AM
  Hydrologic Analysis and Design (2nd Edition) oanm2000 3 3,999 05-01-2013, 07:45 AM
Last Post: ssobhan
  Subsurface Hydrology portal61 1 1,899 12-29-2011, 06:24 PM
Last Post: ska51
  Numerical Methods for Transport and Hydrologic Processes ska51 0 1,677 08-06-2011, 10:02 AM
Last Post: ska51
  Subsurface Flow and Transport: A Stochastic Approach ska51 1 1,926 09-03-2010, 12:59 PM
Last Post: ska51
