Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 8437:2005 Code of practice for selection,
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
12-13-2011, 11:32 AM
BS 8437:2005 Code of practice for selection, use and maintenance of personal fall protection systems and equipment for use in the workplace
Size: 7.78 MB | Format: PDF | Publisher: BSI | Year: 29 April 2005 | pages: 146 | ISBN: 0 580 45817 2
[Image: 13169939981654021807.png]
This British Standard gives recommendations and guidance on the selection, use and maintenance of personal fall protection systems and equipment for use in the workplace to prevent and/or to arrest falls from a height, including systems and equipment suitable for use in rescue. It also gives guidance on rescue of persons working at a height, in the event of an accident.
It is intended for use by employers, employees and self-employed persons who use personal fall protection systems and equipment. It is also intended for use by designers, e.g. architects and structural engineers, including those who are responsible for the design of safe access routes on buildings and structures, by those who commission work at a height, e.g. building owners and contractors, and by those involved in training persons for work at a height.
The standard is not applicable to collective fall protection systems, for example work platforms and fall arrest nets. It is not intended to apply to personal fall protection systems and equipment for use in leisure activities or in professional or private sports activities. It is also not intended to apply to personal fall protection systems and equipment for use in arboriculture.
[-] The following 6 users Like mybest's post:6 users Like mybest's post
  â€¢ 3fan, kowheng, ting tsai huang, Jackass, kvtasp, zrilek
 kvtasp
User ID: 7690
Threads: 60
Likes: 2,028 in 379 posts
Given Likes: 791
12-22-2011, 02:56 PM
[-] The following 2 users Like kvtasp's post:2 users Like kvtasp's post
  â€¢ peixoto, zrilek
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
02-26-2013, 06:37 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
  â€¢
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 8,422 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,998 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 10,458 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,513 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,801 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 5,392 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,626 02-17-2021, 11:20 AM
Last Post: temp1366
