Civil Engineering Association eBooks Journals, Papers and Presentations Response Surface Method for Time Variant Reliability Analysis
 malc
User ID: 30599
Threads: 65
Likes: 1,520 in 155 posts
Given Likes: 15191
10-11-2011, 06:30 AM
Author: T. Jun Yen Yao and K Wen | Size: 2 MB | Format: PDF | Publisher: University of Illinois | Year: 1993 | pages: 115 | ISBN: ISSN00694274
[Image: 70415937388160195266.jpg]
In Civil Engineering the design and analysis of structures is a complex process typically structures are very expensive to build or replace in addition the cost of failure can be very high because people live or work within or travel upon many of the structures designed by civil engineers because of this reliability analysis in civil engineering is very important.
In the reliability area researchers are interested in tools which can reduce computational expense with little reduction in accuracy Response Surface Methodology is such a tool for problems in many areas.
[-] The following 6 users Like malc's post:6 users Like malc's post
  â€¢ Dell_Brett, theanhpe, lizard, Jackass, tluc, ting tsai huang
 rusty
Hungary
User ID: 17227
Threads: 56
Likes: 1,880 in 283 posts
Given Likes: 539
05-17-2013, 08:24 AM
Above links are dead.
Direct link:
[-] The following 1 user Likes rusty's post:1 user Likes rusty's post
  â€¢ kowheng
  Ed Wilson - Termination of the Response Spectrum Method RyanRS 0 5,100 11-27-2015, 10:08 AM
Last Post: RyanRS
  Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 6,126 10-21-2014, 08:57 AM
Last Post: Munykong
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 6,092 09-05-2014, 01:46 PM
  Reliability Analysis of Steel Building Frame Under Earthquake Forces TAFATNEB 0 4,210 05-09-2014, 10:56 AM
  Seismic Reliability Analysis of Cable Stayed Bridges Against First Passage Failure TAFATNEB 0 4,330 05-03-2014, 09:46 AM
  Non-linear time history analysis of tall structure for seismic load using damper TAFATNEB 0 4,031 04-17-2014, 09:48 AM
  Pushover and Seismic Response of Foundations on Stiff Clay: Analysis with P-Delta Eff TAFATNEB 0 4,065 11-23-2013, 11:32 PM
