08-17-2011, 12:33 PM
Anybody having this document pls share...also tell me what does it means by CLASS 1 of BS 476:PART-7?
WS
WS
08-17-2011, 01:54 PM
BS 476-7:1997 Fire tests on building materials and structures Part 7. Method of test to determine the classification of the surface spread of flame of products Author: Technical Committee FSH/21 | Size: 0.3 MB | Format: PDF | Publisher: BSI | Year: 1997 | pages: 24 | ISBN: 0580262987
![]() This Part of BS 476 specifies a method of test for measuring the lateral spread of flame along the surface of a specimen of a product orientated in the vertical position under opposed flow conditions, and a classification system based on the rate and extent of the spread of flame. It provides data suitable for comparing the end-use performances of essentially flat materials, composites or assemblies, which are used primarily as the exposed surfaces of walls or ceilings. Annex A gives guidance to operators carrying out this method of test. Annex B discusses the effect of thermal characteristics on the performance of assemblies and gives advice on the construction and preparation of test specimens. Annex C gives information on the validation of this method.
Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈 |
| [REQUEST] Structural steel design to BS5950 Part 1, Part 1 | nudles | 0 | 1,810 |
11-11-2012, 01:06 PM Last Post: nudles |
| [REQUEST] Request for codes IS 9178 PART 1 , PART2 PART 3 | NAUTILUS87 | 0 | 1,587 |
06-13-2012, 11:45 AM Last Post: NAUTILUS87 |
