SEISMIC INVERSE Q FILTERING
Author: Yanghua Wang | Size: 13.9 MB | Format: PDF | Publisher: Blackwell publishing | Year: 2008 | pages: 250 | ISBN: 978-1-4051-8540-0
![[Image: 51486778860073537349.jpg]](http://pic.civilea.com/images/51486778860073537349.jpg)
When seismic waves propagate through the earth subsurface, the absorptionand dispersion effects will cause attenuation of wave amplitudes and shapedistortion of seismic waveforms. Inverse Q filtering is a wave propagation-reversal processing that removes these effects from recorded seismic data.After inverse Q filtering, seismic data will have improved quality withcorrect amplitudes and phases, which will result in better matching with thewell-log information, higher resolution for thin-layer interpretation andreliable seismic inversion for reservoir characterization
