Civil Engineering Association Software Software Product Bentley Products Bentley WaterGEMS V8i (SELECT series 2) 08.11.02.31
Threads: 1,118
07-25-2011, 09:57 AM
[Image: 34267886373466852124.jpg]
WaterGEMS is a comprehensive and easy to use water distribution modeling application. WaterGEMS can run in ArcGIS, AutoCAD, and MicroStation, or as a standalone application. From fire flow and water quality simulations, to criticality and energy cost analysis, to advanced genetic algorithm optimization, WaterGEMS comes equipped with everything you need in a flexible multi-platform environment.
WaterGEMS V8 extends every piece of functionality across all the included CAD, GIS, and stand-alone platforms. For example, GIS users can now exercise total control over engineering units directly within ArcGIS’s attribute tables, using the same FlexTables technology they can find in the other included platforms.
[Image: tips.png]
30 days trial (size 1000) with renew.
[Image: comments.png]
Downloaded by someone from Lavteam and posted in other places.
[-] The following 19 users Like BennyP's post:19 users Like BennyP's post
  β€’ hazus, malc, jokerβ„’, mgdario, Petrit, oanm2000, Vanfa, TAFATNEB, arspi, nuttapolk, alexjakson, ska51, inglugo, bzaber27, eugeniofbarbosa, ykhackhack, Dell_Brett, Quantumm, fefdbi
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
08-11-2011, 11:14 PM
Mirror:
No limits to creativity
[-] The following 5 users Like jokerβ„’'s post:5 users Like jokerβ„’'s post
  β€’ oanm2000, topgun45, ska51, ykhackhack, Quantumm
Threads: 1,118
11-26-2011, 09:06 AM
Bentley WaterGEMS V8i - Cumulative Patch Set for build 08.11.02.31 6.1 MB
(Version: 08.11.02.31 Date: 8/8/2011)
  β€’ ska51, mahyarov, inglugo, ykhackhack
Threads: 1,118
11-27-2011, 05:08 PM
(Version: 08.11.03.17 Date: 8/23/2011) 266.43 MB
Bentley WaterGEMS V8i - Cumulative Patch Set for build 08.11.03.17
(Version: 08.11.03.17 Date: 10/17/2011) 3.13 MB)
  β€’ mahyarov, inglugo, josetolo_jr, ykhackhack, Dam383
Threads: 1,118
05-27-2012, 07:42 AM
(Version: 08.11.03.19 Date: 2/29/2012 12:00:00 AM FileSize: 266.55 MB)
  β€’ GMianG
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
01-22-2013, 03:30 PM
Patch for Bentley WaterGEMS V8i (SELECT series 2) 08.11.02.31 only test with Win7/64bit
[Image: 21341029925642508718.png]
1. Copy Bentley.liclib.dll to C:\Program Files (x86)\Bentley\WaterGEMS\
2. Apply WGEMS_08.11.02.31_Winx64.bat
3. Run reg file that generated.
[-] The following 4 users Like jokerβ„’'s post:4 users Like jokerβ„’'s post
  β€’ ska51, shezira, emmi, fefdbi
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
01-24-2013, 07:24 AM
AutoCAD Integration with WaterGEMS V8i
When you install WaterGEMS V8i after you install AutoCAD, integration between the two is automatically configured.
If you install AutoCAD after you install WaterGEMS V8i, you must manually integrate the two by selecting Start > All Programs > Bentley >WaterGEMS V8i > Integrate WaterGEMS V8i with ArcGIS-AutoCAD-MicroStation. The integration utility runs automatically. You can then run WaterGEMS V8i in the AutoCAD environment.
The Integrate WaterGEMS V8i with AutoCAD-ArcGIS command can also be used to fix problems with the AutoCAD configuration file. For example, if you have CivilStorm installed on the same system as Bentley WaterGEMS V8i and you uninstall or reinstall CivilStorm, the AutoCAD configuration file becomes unusable. To fix this problem, you can delete the configuration file then run the Integrate WaterGEMS V8i with AutoCAD-ArcGIS command.
  β€’ ykhackhack, seriousboy, fefdbi, emmi
  WaterGems CONNECT 10.03.02.75 poolmand 1 5,902 10-18-2021, 04:53 AM
Last Post: deovrat
  Portable Bentley RAM Connection V8i (SELECT Series 3) 7.3.1 jamildear4u 4 17,022 09-25-2017, 06:25 PM
Last Post: Aviator
  WaterGEMS CONNECT Edition 10.00.00.49 TAFATNEB 1 6,281 12-02-2016, 01:02 PM
  Bentley WaterCAD & WaterGEMS V8i SS6 08.11.06.58 er.shyams 1 7,793 02-22-2016, 07:08 PM
Last Post: cvidalv
  Bentley WaterGEMS v8i Select series 5(08.11.05.61) emmi 2 10,763 09-28-2015, 08:38 PM
Last Post: jokerβ„’
  Bentley WaterGEMS V8i (SELECtseries) 4 08.11.04.50 BennyP 1 6,625 11-21-2013, 09:40 AM
Last Post: jonny78
  RM Bridge (Select Series 3) v08.10.07.02 jokerβ„’ 2 11,352 12-23-2012, 04:28 AM
