Civil Engineering Association eBooks Journals, Papers and Presentations Hot-dip-zinc-coating of prefabricated structural steel components
07-23-2011, 06:27 PM
Author: M. Feldmann, T. Pinger, D. Schäfer, R. Pope, W. Smith, G. Sedlacek | Size: 7.48 MB | Format: PDF | Publisher: JRC – ECCS | Year: 2010 | pages: 110 | ISBN: 9789279152375
[Image: 90578130010784091961.jpg]
(1) This JRC-Scientific and Technical Report gives information from pre- normative research methods to avoid liquid metal assisted cracking of prefabricated structural components during zinc-coating in the liquid zinc melt that may impair the structural safety of structures in which the components are built in.
(2) This information provides a platform upon which further European design and
product specifications can be developed. It may in particular affect the further developments of EN 1993, EN 1090 and EN ISO 1461 and EN ISO 14713.
(3) This report gives the state of the art in understanding the mechanism of liquid metal assisted cracking in the zinc bath and methods and models that may be used to avoid it.
(4) It could be a basis to propose rules for the design of steel components intended to be hot-dip-zinc-coated in such a way that the design is consistent with execution rules for hot-dip-zinc-coating.
(5) The workability of the rules proposed for all metal works and steel works that are fabricated under EN 1090 and galvanized according to the rules in this report is demonstrated by worked examples.
  • gulilero, jcbv, niki102, joker™, Dell_Brett, kowheng, malc, sodapas, mowafi3m, slowet, gafi
 amadoo02
Egypt
User ID: 1374
Threads: 5
Likes: 235 in 40 posts
Given Likes: 48
05-04-2013, 08:25 AM
Please Reupload.
Thank you.
[-] The following 3 users Like amadoo02's post:3 users Like amadoo02's post
  • kvtasp, Jackass, chottabhai
  Design curves for Prefabricated Vertical Drains shadabg 1 5,900 04-19-2017, 03:40 AM
Last Post: tomcat007
  Evaluation of Discharge capacity of prefabricated vertical drain shadabg 1 6,342 04-19-2017, 03:38 AM
  Marine Prefabricated Vertical Drains for the Craney Island Eastward Expansion jacs127 0 4,021 02-09-2013, 05:20 PM
Last Post: jacs127
  Prefabricated Vertical Drains for Enhanced In Situ Remediation shadabg 0 4,313 09-25-2012, 09:47 AM
Last Post: shadabg
  Guideline on Seismic Evaluation and Upgrading of Non-Structural Building Components ir_71 0 4,749 09-27-2011, 04:26 AM
