Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Design of Precast Concrete Piers for Rapid Bridge Construction in Seismic Regions
Threads: 1,298
07-09-2011, 04:28 AM
Author: Jonathan M. Wacker, David G. Hieber, John F. Stanton, Marc O. Eberhard | Size: 3 MB | Format: PDF | Publisher: USDoT & FHWA | Year: 2005 | pages: 252
[Image: 66214706039123735489.jpg]
Incorporating precast concrete components into bridge piers has the potential to reduce the construction time of a bridge and the negative impacts of that construction on traffic flow. Practical methodologies are needed to design economical and safe piers out of precast concrete components. This research developed force-based and displacement-based procedures for the design of both cast-in-place emulation and hybrid precast concrete piers. The design procedures were developed so that they require no nonlinear analysis, making them practical for use in a design office. The expected damage to piers designed with the procedures in a design-level earthquake was estimated. The evaluation considered three types of damage to the columns of a pier: cover concrete spalling, longitudinal reinforcing bar buckling, and fracture of the longitudinal reinforcing bars. Both the force-based and displacement-based design procedures were found to produce designs that are not expected to experience an excessive amount of damage in a design-level earthquake.
  • Notter, araza023, Jackass, bhawk0, jf28, zrilek, nigema, malc, sujups, tluc, mecheil.edwar, warbeast, gulilero, blaze, kowheng
 vutuyen
User ID: 23785
Threads: 9
Likes: 482 in 50 posts
Given Likes: 70
07-19-2012, 03:27 AM
Some links above are dead.
This is the direct link
[-] The following 9 users Like vutuyen's post:9 users Like vutuyen's post
  • miquan, Jackass, kowheng, blaze, smrutigandh.42, Dell_Brett, lucky_b2me, mgdario, SCREAM7890
  Concrete Segmental Bridges: Theory, Design, and Construction to AASHTO LRFD Specific carolinandra 1 3,555 01-03-2022, 07:57 AM
  Innovative bridge design handbook : construction, rehabilitation and maintenance cace-01 2 4,358 11-28-2021, 06:01 PM
Last Post: cace-01
  Concrete Bridges: Design and Construction toa011 3 4,681 10-01-2018, 05:16 PM
Last Post: febo927
  Prestressed Concrete Bridges: Design and Construction abudabeeja 10 11,257 03-28-2017, 12:20 AM
Last Post: gulilero
  Construction and Design of prestressed Concrete segmental Bridges ziggywas1 4 5,451 03-30-2016, 07:30 AM
Last Post: subin91
  Seismic Design Aids for Nonlinear Pushover Analysis of Reinforced Concrete and Steel lamkin 12 8,586 11-23-2015, 03:22 PM
Last Post: ibg0203
  Bridge Engineering: Seismic Design - by Wai-Fah Chen and Lian Duan juice 11 9,261 10-31-2015, 04:43 AM
Last Post: ibg0203
