Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS PD 6691:2007 Guidance on the use of BS EN 13108 Bituminous mixtures – Material spe
06-16-2011, 04:09 AM
BS PD 6691:2007 Guidance on the use of BS EN 13108 Bituminous mixtures – Material specifications
Author: Technical Committee B/510 | Size: 1.4 MB | Format: PDF | Publisher: BSI | Year: 2007 | pages: 84 | ISBN: 9780580507779
[Image: 49386851939859385654.jpg]
This Published Document gives guidance on the use of BS EN 13108-1, BS EN 13108-4, BS EN 13108-5, BS EN 13108-8, BS EN 13108-20 and BS EN 13108-21. Clauses 1 to 10 of this Published Document give general guidance and background information on BS EN 13108. Annex B provides guidance, based on the requirements formerly specified in BS 4987, for producing asphalt concrete that conforms to BS EN 13108-1; Annex C gives similar guidance, based on the requirements formerly specified in BS 594-1, for producing hot rolled asphalt that conforms to BS EN 13108-4; and Annex D provides guidance for producing stone mastic asphalt that conforms to BS EN 13108-5. This Published Document does not give guidance on BS EN 13108-2, BS EN 13108-3, BS EN 13108-6 or BS EN 13108-7 as these are either little used in the UK or covered by other guidance. This document’s application is for roads and other paved areas, but excluding airfields, detailed provisions for which are specified elsewhere.
NOTE 1 Porous asphalt, which was included in BS 4987, is now covered by BS EN 13108-7. Mastic asphalt mixtures previously defined in BS 1447 are now covered by BS EN 13108-6.
NOTE 2 There are several asphalt mixtures in general use which were not historically covered by British Standards but which are now covered in BS EN 13108. These are stone mastic asphalt, covered by BS EN 13108-5, and asphalt concrete for very thin layers (thin surfacing), covered by BS EN 13108-2.
  • kowheng, blaze, Dell_Brett, Trishu999, cace-01, toa011, oanm2000, cod-X, sivlad, asim99, peixoto
Threads: 49
03-12-2013, 02:32 PM
all links dead; reposted here:
password:
  • asim99, blaze, Dell_Brett
 abualamal
Palestine
User ID: 39414
Threads: 11
Likes: 37 in 13 posts
Given Likes: 167
07-09-2015, 06:19 AM (This post was last modified: 07-09-2015, 06:42 AM by usman.)
Dears,
New Link for the file BS PD 6691:2007
Best Regards
[-] The following 4 users Like abualamal's post:4 users Like abualamal's post
  • hodzicemir, Jackass, PinkPant, oanm2000
 PinkPant
Turkey
User ID: 25448
Threads: 67
Likes: 4,007 in 374 posts
Given Likes: 10354
07-09-2015, 09:27 AM
Newest version of BS PD 6691:2010
Use regular forum pass
PinkPant
[-] The following 3 users Like PinkPant's post:3 users Like PinkPant's post
  • Dell_Brett, hodzicemir, oanm2000
